Anyone used or seen one of these?
Discussion in 'General Camping Discussion Forum' started by Whiteycracker, Jun 11, 2018.
  1. Whiteycracker
    Whiteycracker Active Member
    159
    41
    May 22, 2016
    South Chicagoland
    Looks like a neat tool to have on a trip instead of bringing a hydraulic jack in case of a flat or for routine maint.
    https://www.amazon.com/SeaSense-Ton...707522&sr=8-1&keywords=Easy+Lift+Trailer+Axle
    What are your thoughts, or how do you/would you do it?
  2. Raycfe
    14,534
    1,123
    A bottle jack is cheaper and easier to use. ++++
  3. Whiteycracker
    159
    41
    May 22, 2016
    South Chicagoland
    Depending on which bottle jack you choose for the price. And using a jack always has me nervous that someone could damage the axle by putting all the weight in on small concentrated area. Seems like the one above would displace more weight evenly instead of a quarter sized spot ...
  4. Snow
    9,827
    845
    Scissor jacks are super cheap from a wrecker, easy to use and store..
    terry1419 and J Starsky like this.
  5. sleach
    672
    139
    May 17, 2014
    Boulder, Colorado
    Stopped to help a fellow using a device like this on road side. Thin cross section just sank into thin soft, hot asphalt. Scissor jack from my Dodge PU solved the problem.
    Whiteycracker likes this.
  6. Sneezer
    1,438
    469
    Yep. I have a scissor jack from an old truck. That and some lynx blocks along with a decent 4-way and I am good to go. Cheap too.
  7. MsMac
    MsMac Active Member
    575
    243
    May 19, 2016
    Oh God, why do people "invent" stuff like this?????
    Seriously, stick with a scissor or floor jack. And, in the case of doing maintenance at home, for the love of kittens and unicorns, please stabilize the camper with solid wood or something similar before you crawl under it.
  8. J Starsky
    J Starsky Well-Known Member
    648
    423
    Aug 3, 2017
    East Central MN
    $5 jack at my favorite ATV Salvage in NB MN! Love those dudes in a manly man way.
    Maycat, kcsa75 and Katskamper like this.
  9. Sjm9911
    3,640
    1,778
    The warning on it said contained lead, hope that's not the metal that's used to make it!
  10. MsMac
    MsMac Active Member
    575
    243
    May 19, 2016
    Apparently, it's aluminum. Another material that would not be my choice for something to safely support the weight of a camper. :(
  11. J Starsky
    648
    423
    Aug 3, 2017
    East Central MN
    Next model will be made outta concrete blocks for safety [:D][A][:D]
  12. Sjm9911
    3,640
    1,778
    The description said it had a grease fitting also, lol
    J Starsky likes this.
  13. tfischer
    tfischer Well-Known Member
    3,318
    843
    May 21, 2014
    OK maybe I'm slow, but I don't see how this works, and the description doesn't seem to match the product.
    EDIT: Nevermind found a video. Seems like a reasonable solution to me, kind of an Andersen leveler on steroids and using the axle instead of the tire. As for the surface area sinking into the asphalt/dirt, a board underneath would fix that.
  14. DanLee
    DanLee Member
    81
    35
    Apr 28, 2015
    Virginia
    I've had one since we bought our camper new back in 1991. Works great.
    jumpoff likes this.
  15. Sjm9911
    3,640
    1,778
    Now we know they work ! Cool!
  16. jerbear
    jerbear Active Member
    222
    44
    Jun 11, 2015
    Indiana
    Thats right you can find them cheap enough .I bought an extra one for $2 at a sale .Between two of the scissors jacks and some blocks of wood in my camper my wife is ready to change tires if need be LOL Dont tell her I said that .
  17. gladecreekwy
    545
    541
    Sep 25, 2016
    What’s stopping it from tipping over when your yanking on a lug wrench?
  18. nineoaks2004
    6,819
    2,738
    Graceville, Florida
    I do not think it would work to great on dirt or mud, plus you would have to get under the unit to install it and it does not look like it would be stable enough) . I will stick to my small floor jack and or bottle jack. For me the floor jack works better, ( I carry a piece of plywood to use under it ) (My Opinion)
  19. tfischer
    3,318
    843
    May 21, 2014
    Really shouldn't be doing any yanking on any type of jack. Break the nuts loose on the ground, then jack it up to finish the job. Reverse the process to put the wheel back on (just snug them up, then lower it and torque them to spec)
    terry1419, PointyCamper and Toedtoes like this.
  20. J Starsky
    648
    423
    Aug 3, 2017
    East Central MN
    I think the TV in park should work. I also think a block of wood to chock the wheels is a requirement for my tire changing antics. Still not that into this thing...
