Are these adapters all the same?
Discussion in 'Propane - Got Gas' started by Nlittle, Oct 22, 2014.
  1. Nlittle
    Nlittle New Member
    118
    Aug 6, 2014
    Hello,
    Can't camp so have to plan!
    I have a quick connect low pressure connector outside of my pup for the stove/ grill. I often use a camp stove next to it that uses 1lb tanks. I want to be able to use them both off the large tank.
    From what I have read so far I am pretty sure I CANNOT split the quick connect that is already there because the camp stove wants high pressure. (right?)
    I can however T off of the large propane tank up front.
    I found these that all "look" the same but the costs are different.
    http://www.propaneproducts.com/rv-camper-grill-lantern-connection.html
    http://www.amazon.com/Camco-59103-Propane-Brass-Port/dp/B0014JKDB2/ref=cm_cd_ql_qh_dp_t
    http://www.campingworld.com/shopping/item/stay-flow-plus/24020
    Assuming the length is fine (need to measure) would all of these work?
  2. 3hooligans
    3hooligans Member
    622
    Jul 27, 2014
    Boston
  3. rabird
    6,441
    200
    TX
  4. aslag
    aslag Pacific Northwest
    399
    Sep 8, 2008
    Pacific Northwest
  5. 3hooligans
    3hooligans Member
    622
    Jul 27, 2014
    Boston
    Sorry I got caught up in work. I want to do the same thing withy outside connection but face the same challenges as you with Coleman stove requiring HP. I have a tee for the bottle one to connect to the second tank and regulator but have yet to purchase a hose to run the length of where I am using my stove or grill. It is an expensive hose.
  6. Nlittle
    Nlittle New Member
    118
    Aug 6, 2014
  7. swordfish
    swordfish Well-Known Member
    2,204
    32
    Sep 27, 2010
    It is not that simple. I have gone through hell trying to connect my Coleman 2-burner stove with a 10-lb propane tank. (Works flawlessly with the 1-lb cylinder) All fittings were perfect, but no gas coming through, or if it did once in a while the flame went out if I used both burners at the same time and I was unable to start again. There were all kinds of theories - valve must be opened slowly, air lock in line, etc. It was the regulator for the Coleman stove somehow incompatible with anything other than a 1-lb cylinder. I had to cannibalize a different stove for it's regulator and now it is working nicely. Hope you don't run into this problem.
  8. Nlittle
    Nlittle New Member
    118
    Aug 6, 2014
    What do you mean here? At the stove side itself? Can you post a picture? Maybe keep using small tanks? LOL
    It really seems like this should be something that just works with the right connections.
  9. adrianpglover
    adrianpglover Active Member
    1,478
    Jul 8, 2014
    Texas
    That's interesting because I've never had a problem using my Coleman distribution tree. I was just hoping I could use the camper as the tree instead.
    http://www.academy.com/webapp/wcs/stores/servlet/Product_10151_10051_26061_-1__?N=129184655&affcode=42&kwid=ps_cse&cid=PLA_000695411&affcode=42&kwid=ps_cse&cid=PLA_000695411&gclid=CILf7u6JwcECFcpzMgodABYAOw
    We used these things all the time in scouts. It was nice to have your lantern above you while you're cooking, plus the bottle makes a nice anchor to keep the whole setup upright.
  10. Dubbya
    6,125
    46
    Aug 2, 2011
    Steinbach, MB
    You can't fuel a camp stove or grill using the RV quick connect because it already has one regulator on it and doesn't supply enough pressure to operate a second regulator.
    If you have the right fittings, you might be able to replace the grill's regulator with one of these low pressure conversion valves (or the kit with extension hose) from Camco.
    http://www.camco.net/Products/Item?prodID=10715#.VEgPdRZEvng
    Bear in mind that you may have to swap out the male quick connect fitting(s) to be able to use your camper's female fitting as there are two types of quick-connect fitting. One has a cross inside (common on older RV's), the other (newer and aftermarket) doesn't. Your RV dealer can help you figure out which fitting you need to be able to make it work.
    Alternatively, what you're looking at is a splitter that attaches directly to the tank. I sure love mine and use it all the time.
    Mod thread here: http://www.popupportal.com/index.php?topic=74552
  11. swordfish
    2,204
    32
    Sep 27, 2010
    This is a Coleman stove with it's stock regulator. Great for the 1-lb canister.
    I had to use the regulator from Primus Gour-Mate stove and discard the Coleman regulator.
    This works flawlessly directly from a 10-lb or 20-lb tank; not via quick connect to the low pressure line.
    Please note that the Coleman regulator was not defective. It was just not working with a tank. The part goes into the Coleman stove was still a Coleman part because the Primus stove fitting does not fit the Coleman stove.
  12. rabird
    6,441
    200
    TX
    Awww, the good ole days when a Coleman trailer came with a Coleman stove.
  13. swordfish
    2,204
    32
    Sep 27, 2010
  14. Islandwoman20
    Islandwoman20 New Member
    Jun 1, 2014
    As a notorious overpacker, my goal this year is bring less stuff, including the extra propane tank I lug around from my days of tenting. I'm looking to hook up my bbq grill to my popup's propane tank. Thanks for making this post!
  15. 94-D2
    94-D2 Happy Campin'
    2,278
    112
    May 21, 2010
    Sutter Creek CA
