Atwood 7916-ii blows cold air even if switch is off
Discussion in 'Heating / Cooling Systems' started by jessMN, Jun 15, 2019.
  1. jessMN
    jessMN Member
    39
    May 18, 2019
    Minnesota
    Ok so really that's two issues. One problem is that it's not igniting but the weirder problem is that even if the furnace switch is off, it blows air. The only way to stop it is to pull the fuse. I'm hoping that if I take it out and clean everything up we might be good on the igniter but what about the air thing?
  2. BigAl
    BigAl Member
    43
    35
    May 22, 2019
    Wisconsin
    Is there a separate on/off switch on the thermostat apart from the temp setting? I had thought that pushing the temp all the way down would turn it off, but then learned there is a separate off switch on the bottom of the thermostat.
  3. WrkrBee
    WrkrBee Well-Known Member
    1,935
    726
  4. jessMN
    jessMN Member
    39
    May 18, 2019
    Minnesota
  5. jessMN
    jessMN Member
    39
    May 18, 2019
    Minnesota
    Nope. Just on the furnace. But even if there was one I'd think the furnace switch would be the master. I'm just perplexed why it would blow even when switched off. :(
    Of course the thermostat is old as is the furnace) maybe it's a combination of problems
  6. WrkrBee
    1,935
    726
    Looking at the manual, the blower function is controlled by the DSI board. The BLW connection feeds the fan motor. Could be a small relay on the board that has failed "closed".
  7. jessMN
    jessMN Member
    39
    May 18, 2019
    Minnesota
    Ah, thank you, I will check that out
