Atwood furnace blows but no ignition
Discussion in 'Heating / Cooling Systems' started by MaeKay, Jun 9, 2018.
  1. MaeKay
    MaeKay Active Member
    585
    184
    Oct 18, 2017
    Utah
    304A440C-FFB4-422D-BBE4-09E444E76CD2.jpeg I’ve read through a lot of threads on this issue but I still have questions. My furnace worked in March (both shore power and 12V). Now it will blow but then no ignition. I don’t even hear the click click click of it trying to light. (Double checked gas is on...had the gas stove running for a bit...)
    It’s an Atwood 7916-II
    It did this in March and all I had to do was press the reset button. That’s not working now.
    If I need to check a sail switch, where is that? If I need to clean spiderwebs from a vent...where is that? And if I need to replace the DSI board...I think I know where that is.
    Last question: what is that red light blinking on what I think is the DSI board. Could that be something as simple as a fuse? (It’s behind the back of the board, and I’m afraid to take it apart if I don’t have to)
  2. MaeKay
    585
    184
    Oct 18, 2017
    Utah
    Ok, did more digging by googling “flashing light” and discovered this from a post from 2009. The blinking is a diagnostics code.
    Limit switch/Airflow problems 1 flash with 3-second pause
  3. MaeKay
    585
    184
    Oct 18, 2017
    Utah
    My guess is a hornets nest in the vent. I’m going to attempt to unscrew it and clean it out. But it looks sealed with caulk so we’ll see. I’ll keep you posted with a running commentary...lol
    Dback2k4 likes this.
  4. Dback2k4
    Dback2k4 Active Member
    363
    168
    Jul 16, 2017
    Iowa
    If you've done any battery maintenance recently make sure your + and - aren't reversed, that will cause the fan to spin (in reverse) but not open the sail switch. Otherwise could be a blockage of gas. Careful with those hornets.... nasty buggers!
  5. MaeKay
    585
    184
    Oct 18, 2017
    Utah
    Back in March we had our terminals switched. And it blew a 20amp fuse which we replaced. Now I’m pretty sure we have it correct but it never hurts to check. (Hence making sure the gas was actually on. Haha). Black is positive and white is negative, correct? And right now it’s even plugged into shore power.
  6. MaeKay
    585
    184
    Oct 18, 2017
    Utah
    You’re telling me! They’re everywhere in our neighborhood. They love to build nests on our door frames or the kids swing set. And we already knocked one off the roof seal of the trailer and I do see one inside the vent, the start of a tiny one.
    Blessedly we’ve only experienced one sting in the almost 5 years we’ve lived here. My son is a champ and also not allergic.
  7. MaeKay
    585
    184
    Oct 18, 2017
    Utah
    Yep. It’s caulked. Should it be? If so it’s a fairly easy thing to recaulk. And if so, what type of caulk is best?
  8. MaeKay
    585
    184
    Oct 18, 2017
    Utah
    jnc likes this.
  9. MaeKay
    585
    184
    Oct 18, 2017
    Utah
    Yeah, didn’t think it would be that easy. Also didn’t think something that small would cause a problem.
  10. MaeKay
    585
    184
    Oct 18, 2017
    Utah
    Now to figure out how to disassemble and check the voltage on the limit switch and sail switch. I kind of feel empowered. I’ve never done anything like this.
  11. Sjm9911
    3,315
    1,549
    Is it a limit switch like on a regular furnace? If so it has a button to reset it. They go bad a lot also, and are like only 3 bucks to buy. I wouldent bother with the voltage , eaither it works or dosent. Easy test to see if that's the problum is to by pass the switch. I was never good with a volt meeter.
  12. MaeKay
    585
    184
    Oct 18, 2017
    Utah
    In the very first post the picture shows a black/brown switch on the right, above the DSI board. Is that what you’re talking about? Because I’ve reset it a few times.
  13. MaeKay
    585
    184
    Oct 18, 2017
    Utah
    Actually I just found this diagram. The switch I mentioned is the circuit breaker switch.
    http://pdfstream.manualsonline.com/c/c950e617-f467-4c97-8261-b1313b50eac8.pdf
    The limit switch is #18. Still have to take it apart and try to find that little sucker. (We had to make a run to the grocery store). And I have someone hopefully coming to look at buying it in a couple hours!
  14. Sjm9911
    3,315
    1,549
    This is the one I'm familiar with, but there are other styles. So Google the brand of furnace and limit switch to see what you have.
    MaeKay likes this.
  15. Sjm9911
    3,315
    1,549
  16. Sjm9911
    3,315
    1,549
    Ok cool, progress is progress. Like I said if it resets and works, your good to go. If it doesn't try to bypass it, just run a temporary wire from one side to the other, if it works you need a new switch, if it dosent it's something else.
    MaeKay likes this.
  17. MaeKay
    585
    184
    Oct 18, 2017
    Utah
    That seems like a simple option! I’ve never wired anything but I’ve been watching my husband and our neighbor recently. Here goes!
  18. Sjm9911
    3,315
    1,549
    You ahouldent have to take a lot of stuff apart to get at it. In a regular furnace anyway,
  19. Sjm9911
    3,315
    1,549
    You can just use a price of wire and attach it to the nut, or buy a cheap jumper from harbor freight with alligator clips.
    MaeKay likes this.
  20. MaeKay
    585
    184
    Oct 18, 2017
    Utah
    How does one unscrew a screw with this little of clearance? About an inch? I’ve seen bent screw drivers before but not ones this short. I’m attempting to unscrew it with pliers but that’s not working at the moment.
    But once I get it I screwed, yes, there were only 2 screws holding it in place.
