Atwood furnace blows but no ignition
Discussion in 'Heating / Cooling Systems' started by MaeKay, Jun 9, 2018.
  1. jnc
    3,909
    1,157
    Oct 1, 2014
    South Central New Hampshire
    a Long screwdriver bit in the cordless drill will make short work of it. Or Just a long screwdriver.
  2. MaeKay
    MaeKay Active Member
    585
    184
    Oct 18, 2017
    Utah
    You mean coming through from the other side? (My finger is sort of pointing..)
    The head of the screw driver is on the outside, facing the bunk end. I attempted to take the entire box out but, duh, the furnace is HEAVY and I can’t seem to get it far enough out.
  3. Sjm9911
    3,315
    1,549
    Can you just reach up and hit the little button on the switch? I'm sure they didn't design it to be taken apart every time it needs to be reset, I could be wrong.
  4. MaeKay
    585
    184
    Oct 18, 2017
    Utah
    I can’t reach or see anything. The DSI plate blocks it.
    Well, I was able to bend the metal easily but I’m still not sure what I’m looking at.
  5. Sjm9911
    3,315
    1,549
    I think it's the round black thing with the 2 wires on eaither end of it. Feel both sides of it for a dot, it's a push switch
  6. Sjm9911
    3,315
    1,549
    The small on that's close to the furnace.
  7. Sjm9911
    3,315
    1,549
    A limit switch, or rollout switch gets triggered by heat that rolls out of the furnace box, so it will be closest to the furnace box. It cuts off the power to the unit before you get a fire, a clogged vent can also make this happen, or a windy day with a down draft on your flue
  8. jnc
    3,909
    1,157
    Oct 1, 2014
    Sorry I thought you were trying to pull the whole heater out.
    MaeKay likes this.
  9. Bowman3d
    Bowman3d Active Member
    753
    243
    Apr 13, 2015
    LaLa land (SoCal)
    I can’t tell from the pic but is the screw head like a bolt head if so use a small wrench. Keep us posted.
  10. Sjm9911
    3,315
    1,549
    It should come out with a quarter turn. It's small
  11. Sjm9911
    3,315
    1,549
    No need for tools
  12. Sjm9911
    3,315
    1,549
  13. MaeKay
    585
    184
    Oct 18, 2017
    Utah
    Guys, I feel like a dork. My husband woke up and asked, “Why not just use a socket wrench?” (A regular wrench didn’t work)
    I think the limit switch is the small round thing with two pink wires coming out of it.
  14. MaeKay
    585
    184
    Oct 18, 2017
    Utah
    My other question is if it’s just an Airflow thing, where are the pipes that need to be cleaned out?
  15. Sjm9911
    3,315
    1,549
    Limit switch , I think.
  16. Sjm9911
    3,315
    1,549
    I haven't a clue. I really only know a bit about regular furnaces, I never looked at the one on my camper yet!
  17. Sjm9911
    3,315
    1,549
    It should have a reset button on one side or the other.
  18. MaeKay
    585
    184
    Oct 18, 2017
    Utah
    Haha, well you have now! We’ve got the limit switch unscrewed from the back plate but no clue how to by-pass it.
  19. MaeKay
    585
    184
    Oct 18, 2017
    Utah
    And thank you for helping me get this far.
  20. Sjm9911
    3,315
    1,549
    Did you try the reset , there is a button, run you finger over it on both sides.
