Audi Q7
Discussion in 'Tow Vehicles, Hitch & Towing' started by chrispt, May 22, 2019.
  1. chrispt
    chrispt Member
    36
    Mar 27, 2019
    Midlothian, VA
    Never did I realize how grueling it would be to find a tow vehicle for our 2007 Fleetwood Niagara.
    I think we may have a couple options that will work but wanted to ask everyone. We are now looking at a 2012 Audi Q7. It has the factory installed tow package which per Audi will tow 6615 lbs, with a max tongue weight of 662 lbs. One thing though is they say a WDH is not recommended (I had to find this in the Audi forums). We have one presently, but I assume I could just not use it and use a separate ball with the 2" receiver?
  2. Adam H
    Adam H Active Member
    354
    124
    Aug 22, 2015
    What's the payload capacity of the Audi? You may be having the bumper drag the ground when you hook the Niagara up.
  3. Dingit
    Dingit Well-Known Member
    709
    292
    Mar 8, 2017
    It's a heavy trailer but you might not need a WD (you can still get a stand-alone sway bar). I don't know anything about this Audi, but it sounds heavier duty than the other ones you were looking at. Does it have the adjustable suspension thingy? That should keep it level, assuming it's not too much weight.
  4. Spridle
    Spridle Active Member
    748
    29
    Jun 6, 2011
    This got tossed around a lot with the BMW X5 and race trailers. The X5 diesel is a total beast of a TV by the way. The Euro market does not use WDS hitches and there's some random info that the auto leveling and things like that may not be happy with a WDS hitch. If it were me, I'd use it.
  5. chrispt
    chrispt Member
    36
    Mar 27, 2019
    Midlothian, VA
    So, the dealer we are talking to let us do a 24 hour test drive. I brought it home and put the hitch on for the WDH without the torsion bars. I hitched it up just on the ball and saw no noticeable sag in the back. The factory spec with the tow package (which is what is on it) says 6615 and 662 lbs for tow and tongue, respectively. This one is actually a TDI as well. Not sure on the adjustable suspension but I feel like after this long arduous search maybe it is nearing it's end finally (fingers crossed)
  6. Dingit
    709
    292
    Mar 8, 2017
    But is it a good color? :)
    It does sound like a winner!
  7. Ken Lane
    Ken Lane Active Member
    111
    63
    Apr 16, 2019
    Knoxville TN
    When I tried to find a WDH for my GLK 350 I found out that because of the way the receiver hitch attaches to the car a WDH was not possible The GLK receiver hitch does not have any longitudinal supports extending from the hitch mounts down either side. I have the hitch attaching to the unibody at a point on either side of the rear of the GLK and then a bar and plate extending from the center of the hitch receiver that attaches to the front side center of differential on the IRS. Without the longitudinal frames on the sides there is no way for the hitch load to extend down the unibody chassis to front wheels. Contact E Trailer by phone and they can help. Phone 800-298-8924. I hope you have better news than I did.
  8. chrispt
    chrispt Member
    36
    Mar 27, 2019
    Midlothian, VA
    I think as someone mentioned, I can just use it without the torsion bars and add the sway bar into there. It's in for a PPI right now, so hoping it's all good news!
  9. WrkrBee
    WrkrBee Well-Known Member
    1,727
    628
  10. MileHigh
    MileHigh Active Member
    411
    31
    Jul 18, 2012
    Denver
    TDI = Turbocharged Direct Injection. Used on VW diesel engines.
  11. eoleson1
    eoleson1 Well-Known Member
    1,933
    472
    Jul 5, 2011
    Macomb County Michigan
    PPI - Pre Purchase Inspection?
  12. Dingit
    709
    292
    Mar 8, 2017
    Won't a diesel engine weigh the front end down negating the need for WDH? :)
  13. chrispt
    chrispt Member
    36
    Mar 27, 2019
    Midlothian, VA
    Yep!
  14. chrispt
    chrispt Member
    36
    Mar 27, 2019
    Midlothian, VA
    This is my first diesel, so I don't really know :)
  15. Dingit
    709
    292
    Mar 8, 2017
    They tend to be super heavy--and they also tend to be great for towing.
    But I still don't know anything about Audis. It just sounds like a good thing!
  16. Eric Webber
    Eric Webber Active Member
    159
    91
    Jul 7, 2018
    Montreal, Quebec, Canada
    Its closely related to the Touareg and the Cayenne - both of those are insane for towing. I seem to remember when the Touareg first came out, the towing capacity was "yes"
  17. chrispt
    chrispt Member
    36
    Mar 27, 2019
    Midlothian, VA
    So I think we are going to take out our Niagara for a true camping experience this weekend. Should I use the torsion bars or no?
  18. Dingit
    709
    292
    Mar 8, 2017
    Better start a new thread on that so it gets the proper attention. I don't know if you can use a WD hitch without attaching it all the way. But I'm sure someone here does. :)
    Ideally, you'd want to get a plain old draw bar of the correct height, hook it up, and see if it lifts the front of the TV.
