August 2018 - What did you do for your camper this month?
Discussion in 'So, What Did You Do For Your Camper This Month ?' started by kitphantom, Aug 1, 2018.
Thread Status:
Not open for further replies.
  1. kitphantom
    11,288
    547
    Battery charge/maintenance reminder for those who need it. I know I do, since our TT has been plugged in for months, so we need to check the water level.
    After several hail storms, I decided I should look at the TT's roof. We've only had pea-size to half in hail, but still seemed like a good idea. From what I can see from the house roof, it look good, but it is about time to do a wash and treatment anyway. (I don't do ladders, we have a flat roof, with stairs to get there.)
    I reset the max/min thermometer. Top cabin temp has been 102 over the last couple of days. Freezer has stayed in the teens (it was 11 this morning) and refrigerator topped out at 37.
  2. Sjm9911
    2,329
    887
    Drilled out the rivets and then rescrewed the storage door under the door. It was ripped off. Took the pup to get the brakes checked and adjusted. I'll get it back t omorow and then it's organizing time as we head out for lake George in 3 weeks! Also i should maybe practice driving with it, probubly not.......
  3. DJS12354
    DJS12354 Well-Known Member
    1,532
    457
    Sep 21, 2017
    Plugged it in to charge battery and cool fridge down in anticipation of this weekend's outing.
  4. xvz12
    xvz12 Well-Known Member
    672
    325
    Apr 6, 2017
    New Plymouth, ID
    Looked longingly at our pup as I pulled into the driveway.....next camp isn't till the end of August..... & it's too damn hot to work on it in the evenings. I have a couple of small projects I want to do, but not till it cools down a bit.....supposed to be a lot cooler for the weekend, maybe then
  5. jnc
    3,896
    1,139
    Oct 1, 2014
    South Central New Hampshire
    I bought a new Camp Chef oven for the DW.
    Katskamper and PopUpSteve like this.
  6. silvermickey2002
    4,371
    232
    Sep 11, 2008
    Morris County, NJ
    After returning from our Michigan trip I will go thru the whole pup and see what loosened up and needs fixing. There are two wood screws that hold the furnace in place in the cabinet and one of them fell out! Went to go screw it back in and it would not tighten. So did the old wooden matchstick trick. Put some wood glue on a matchstick and shoved it in the screw hole. Let it dry and trimmed the matchstick. Drilled a new pilot hole and now the screw is nice and tight!
    Also have an issue with some of the exterior trim screws backing out from vibration. Fixed that too! Took the screw out and squirted some clear silicon caulk into the whole and put the screw back in. I have tried LockTite in the past but the screws still tend to back out. So far the screws I have used the silicon in have not backed out.
  7. kitphantom
    11,288
    547
    @silvermickey2002 - checking for loosened fasteners is part of our routine, though there are always those that we don't notice until they're really loose. We have to tighten ones along the bottom of the siding, and have done the toothpick trick with a couple.
    We had to go to larger fasteners on the furnace grill, since they kept working out.
    The sneaky one for us in the TT was the microwave. We finally figured out that the adjustable feet it stands on in the niche would jiggle all the way back in, so it was suspended by the front garnish frame. Courtenay made a base for it to sit on.
    Sjm9911 and silvermickey2002 like this.
  8. emoney
    emoney Well-Known Member
    879
    441
    Jul 7, 2018
    That’s what I did! After 3 weekends of hard labor and a maiden voyage to the beach I am happy to be able to put the cover on until the next trip (Labor Day). It feels good to do nothing to it, lol. Of course I still need to replace the one bed rail but that will need to be ordered etc.
  9. Pnut
    Pnut Member
    56
    23
    Jul 8, 2018
    NE Georgia
    A trick I learned to fix striped holes in wood is using a matchstick or toothpick as stated above but also use some super glue in the hole. I use some from the hobby shop used to make model airplanes and it's called thin ca. It is like water it's so thin. You put your match sick in the hole and squirt some of the glue in the hole and it will get very hard. Be very careful with the glue because it is so thin it will run out of the hole if you use too much, so I use a paper towel right under the hole in case it runs out. Also it will instantly stick your fingers together or anything you touch. You may be able to find it a craft store.
  10. crazymama30
    crazymama30 Active Member
    316
    120
    Apr 1, 2017
    I had the wheel bearings done in anticipation of our August trip. I also fixed the hole in the floor from the flat tire last month.
  11. kitphantom
    11,288
    547
    We topped off the batteries, since the TT has been plugged in since some time in April. 3 cells needed just a bit of water. As usual, when the batteries (or battery when we had just one) have been disconnected, there was a lag time before we had power again after reconnecting. Never have figured that out.
  12. Rusty2192
    Rusty2192 Active Member
    702
    209
    Jul 30, 2014
    Kentucky
    I packed up the pup and took out what we won’t need on this trip. It’s different than most in that there’s no hookups and it’s in bear country (Elkmont Campround in the Smokies) so I added stuff for dry camping and took out some things I won’t be using like my outdoor galley setup and stove (I’ll be using a Coleman stove away from the pup).
    Then I busted out the trusty Speedy Stitcher to patch a failing seam on the bunk end that’s been on my to-do list for a while.
  13. PopUpSteve
    PopUpSteve Administrator
    17,823
    924
    Dec 22, 2002
    Malvern, PA
    Got a few things done this weekend.
    Finally managed to fix my awning which the edge beam had gotten bent in a heavy rain storm last year. Yes, I did have it tilted but it was one of those flash flood type storms.
    I put a tire cover on the spare. I could have gotten one with a PopUpPortal logo on it but it wouldn’t be seen with the TrashARoo backpack on the tire.
    BikeNFish and Sjm9911 like this.
  14. Sjm9911
    2,329
    887
    Got this today through Amazon, 18.50 . It replaced the older 18 yo Colman bags, the bags were on there way out so I saw this and was sceptical but it looks good and it fit in so tight, I don't even have to tie it down.
    Orchid and PopUpSteve like this.
  15. pasobuff
    pasobuff Active Member
    396
    27
    Aug 6, 2012
    Upstate NY
    I started laying out the new flooring in the camper.....hoping to work on it more tonight.....the pain in the neck part will be the angled sections where cabinets and the sink are, but I think I have that figured out. I even managed to get the door threshold up, but I do have to figure out how to get it to sit flush.......
    Sjm9911 and PopUpSteve like this.
  16. Halford
    Halford Well-Known Member
    3,500
    484
    Sep 28, 2011
    Santa Clarita, California
    Just bought and replaced old mattress with new mattresses on both bunkends. to my surprise, the old mattress was 3 inches and the new one is at 4 inches. I added floor padding under the mattress for extra comfort.
    Sjm9911, pasobuff and emoney like this.
  17. BikeNFish
    BikeNFish Well-Known Member
    2,015
    1,139
    Apr 24, 2017
    Maplewood, MN
    Bought a roll of Reflectix so that I can cut out window inserts.
    I will cut out the inserts this next long weekend (Thursday to Monday) while pupping on the Minnesota/Canada border.
    Sjm9911 and pasobuff like this.
  18. PopUpSteve
    17,823
    924
    Dec 22, 2002
    Malvern, PA
    Get a roll of the silver foil heater duct tape for the edges. That will help protect the canvas and the screens.
    Katskamper, Sjm9911 and BikeNFish like this.
  19. BikeNFish
    2,015
    1,139
    Apr 24, 2017
    Maplewood, MN
    Great tip! Thanks!!
    Katskamper likes this.
  20. PopUpSteve
    17,823
    924
    Dec 22, 2002
    Malvern, PA
    Sjm9911, BikeNFish and jnc like this.
Thread Status:
