Bad rear seal?
Discussion in 'Tires / Brakes / Bearings / Axles' started by Matt Benoit, Apr 3, 2018.
  1. Matt Benoit
    Matt Benoit Active Member
    328
    180
    Jul 30, 2017
    Warren, MI
    Hey guys, I replaced my hubs yesterday (including new bearings, races and seals). After the install, I drove around for 30 minutes, and noticed that there is some grease on the back of the hub. I can't tell if it's leaking past the seal, or if as I was installing the hub, the grease that was on the spindle was "pushed" to the back of the hub as the seal slid on the spindle... Here's a picture of the back of the hub. Thanks for the help. 20180403_091557.jpg
  2. tombiasi
    4,756
    568
    Looks normal to me. Keep an eye on the nice white rim after highway speeds. If you are leaking you will see a nice decoration on the rim.
    xxxapache likes this.
  3. BelchFire
    1,677
    393
    Mar 29, 2012
    SE Georgia
    Take a clean rag and try to remove the excess grease, then go for another test drive. If it comes back, it's a bad seal; if not, you're probably good to go.
    jnc and Matt Benoit like this.
