BAL Leveler
Discussion in 'First Time & New Camper Owners' started by chrispt, Apr 17, 2019.
  1. Eric Webber
    Eric Webber Active Member
    159
    91
    Jul 7, 2018
    Montreal, Quebec, Canada
    Less the tongue weight first. It’s a tripod
  2. GreyFox
    GreyFox Well-Known Member
    885
    387
    Oct 10, 2018
    S Ontario
    Those who do prefer to use the supplied wrench would find it much easier to use by extending it's length and thereby reducing the torque required to turn the drive screw.
    Jonson01 likes this.
  3. nhlakes
    nhlakes Well-Known Member
    643
    316
    Oct 15, 2011
    DE and NH
    Cordless drill with 3/4? Socket zips both the stabilizers and the BAL up/down in seconds. Only way to go for me.
    Wish there was an easy way for me to get a drill on the BAL X-chocks. These are awesome for adding stabilization for tandem axle trailers.
  4. GreyFox
    885
    387
    Oct 10, 2018
    S Ontario
    I always used the supplied manual wrench with my X-Chocks but have you considered a right angle drill adapter?
  5. nhlakes
    643
    316
    Oct 15, 2011
    DE and NH
    There's really not enough room for a drill with my setup due to fender and ground. And honestly, now that I actually stop, look at a pic and think about it, I'm not sure it would save much time at all. They only takes a few turns with the wrench to loosen/tighten.
    LOVE the BAL X-chocks though. I dislike camper movement while walking around inside and the X-chocks really help with stabilization.
  6. erich82
    erich82 Active Member
    143
    69
    Mar 12, 2019
    So your tongue weight is 1/3 of the weight of your camper? Guess I'll need a 3/4 ton truck to pull my 2000lbs camper to support that 666lbs tongue!
    ODBadger likes this.
  7. Eric Webber
    159
    91
    Jul 7, 2018
    In an ideal world, with the trailer perfectly lever and zero flex on the tires or jack, it actually would be an even three way split. A tongue scale or a tow vehicle has flex so the weight distribution comes into play.
  8. Eric Webber
    159
    91
    Jul 7, 2018
    But it isn’t an ideal world and the spread is such that even in almost a perfect case, adding a 500lb weight to the tip of the tongue would not distribute it back to the tires.
    I’d say it’s closer to gross weight minus tongue weight divided by two.
  9. erich82
    143
    69
    Mar 12, 2019
    Eh no. I can't even believe someone is saying this...
    In no perfect world would the tongue weight be 1/3 of the camper weight. That would be absolutely horrible.
    Do you know what 33% of the trailer weight on the tongue would do? You'd have a VERY bad time.
    Trailers are designed to come into safe allowable tongue weights, which fall between 10-15%. Manufacturers usually aim at 12-13%.
    At 33%, your trailer would nose dive and your TV wouldn't have traction. Larger trailers would become untowable (imagine a
    2300lbs TW on a 7000lbs trailer lol).
    gladecreekwy likes this.
  10. Eric Webber
    159
    91
    Jul 7, 2018
    I mean perfect math with no variables. Not perfect distribution for towing it.
  11. erich82
    143
    69
    Mar 12, 2019
    It's not even perfect math. The weight distribution percentage of a trailer largely depends on the axle placement. Even if the weight of the trailer was evenly distributed, from back to tongue, it still wouldn't be 1/3, because the axle is not on the back bumper...
  12. gladecreekwy
    486
    457
    Sep 25, 2016
  13. erich82
    143
    69
    Mar 12, 2019
    Your TT weighs 39,000lbs? Lol
  14. gladecreekwy
    486
    457
    Sep 25, 2016
    5 bathrooms
  15. chrispt
    chrispt Member
    36
    Mar 27, 2019
    Midlothian, VA
    Do you keep that on there all the time? I imagine it also helps to keep dirt from getting on it as well.
  16. tombiasi
    4,952
    716
    Not really divided by three since there is only about 10 to 15 percent of the weight on the tongue.
  17. erich82
    143
    69
    Mar 12, 2019
    Do they make that in a mini-van towable bumper pull?
  18. GreyFox
    885
    387
    Oct 10, 2018
    S Ontario
    All the time except when the leveler is being used.
    chrispt likes this.
