Battery Charge Question
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by Mattda, Jun 11, 2019.
  1. Mattda
    Mattda New Member
    25
    Sep 4, 2018
    I have a 2010 Flagstaff 246D. I plan on going camping next week and the place we are going is 2hrs away. So from what I understand if I put the refrigerator in 12v mode before we leave, my SUV will charge the camper battery while driving correct? It would be nice to have the fridge at least starting to get cold before we get there. I don't wanna drain the battery because I have a power top. Thanks
  2. neighbormike
    1,928
    1,211
    Oct 6, 2012
    WI
    You are correct, provided your TV is wired correctly and you have 12v at the aux. pin.
    nineoaks2004 likes this.
  3. MileHigh
    MileHigh Active Member
    431
    42
    Jul 18, 2012
    Denver
    What neighbormike said. I always run my refrigerator on 120 volts for several days before leaving. It's my understanding that there is a considerable draw on 12 volt operation and you may run your tow battery down if you stop for several hours. I also try and pre-cool the refrigerator using icepacks before going. That really helps keep things cool.
  4. Mattda
    Mattda New Member
    25
    Sep 4, 2018
    I have 2017 Honda Pilot with 7 pin factory wire harness. I don't plan on stopping or shutting vehicle off while in 12v mode.
  5. ezakoske
    ezakoske Active Member
    502
    57
    Nov 30, 2014
    Escondido, CA
  6. bheff
    bheff Active Member
    403
    134
    Feb 24, 2011
    NW Arkansas
    It's a toss up whether I'll use 12v or propane while traveling but I always try to park it level when I stop and unplug the tow vehicle just in case. Otherwise it has never been a problem. Double check the plug though and make sure it is connected to power. My GMC and Ram pickups had the wire but I had to connect them to the batter for them to me hot.
