Battery, fuse replacement
Discussion in 'Wiring' started by Nanapoppypops, May 19, 2019.
Tags:
  1. Nanapoppypops
    Nanapoppypops Member
    172
    Mar 30, 2019
    Bought a new 12 volt RV deep density battery. Since we were having a problem with lights, I was told to change the fuse next to battery in case. Does anyone know what size fuse I would need? Battery is 10 x 9 x 6" in size. Thank you. I bought a 30A ATO fuse. I could not tell what was in there before because the number was worn off.
  2. Snow
    9,822
    842
    If it were a fuse. They are colour coded.. IIRC 30amp fuses are green. Or did you have a resetable circuit breaker?
  3. Anthony Hitchings
    290
    95
    Mar 2, 2019
    There "should" be two relevant fuses. The larger "battery" fuse, and the smaller fuse on your branch circuit for lighting. There may be one more large fuse where the +12V lands on your power center (converter).
  4. joet
    4,256
    754
    You will have 1 fuse. It won't be any larger than 30 amp at the battery. Your convertor will have smaller fuses
  5. Nanapoppypops
    172
    Mar 30, 2019
    After purchasing 30A fuses, I looked at the old fuse I replaced and, although you couldn't read the number on it anymore, I found it and it was a 15 and it was blue. Never knew they were color coded. So a new 15 is in place for the battery. Our converter has three 15 and one 30 fuse. Learning new things everyday. Thanks for your help
  6. Nanapoppypops
    172
    Mar 30, 2019
    Not re-settable. The battery fuse wound up being a 15 afterall. No one could read the number any longer but didn't realize they were color coded.
  7. Nanapoppypops
    172
    Mar 30, 2019
    Replaced battery fuse with a new 15. It was a pretty old fuse and the number was hard to see but was found. Still exploring this NTU pup. The converter has three 15 and one 30 fuse. Thanks for help
  8. Nanapoppypops
    172
    Mar 30, 2019
    It wound up being a 15, old fuse and number hard to see. Never realized they were color coded. Just learned that from Snow! Thank you
  9. BillyMc
    BillyMc Well-Known Member
    678
    274
    Mar 25, 2018
    15 amp sounds kinda small. Other than light what do you have that runs on 12 volt?
  10. Nanapoppypops
    172
    Mar 30, 2019
    I'm not really sure but other than the lights inside, there is a water heater, water pump, stove, frig, air conditioner, overhead fan. Won't be using frig or air conditioning
  11. theseus
    theseus Centerville, OH
    2,798
    388
    Feb 6, 2007
    Centerville, OH
    Water pump, over head fan, and fridge all use DC power. However don’t use the fridge on DC. It will just drain the battery really fast.
    You didn’t mention a furnace. That would also use DC power for the fan.
    The A/C and your 120 outlets will not use the battery at all. If you are dry camping (boondocking) they will not work.
  12. Nanapoppypops
    172
    Mar 30, 2019
    Okay. What's a good size fuse for the battery, 15A or 30A. Thanks for help
  13. theseus
    2,798
    388
    Feb 6, 2007
    Centerville, OH
    I use a 30A at the battery and smaller ones for the branch circuits. The branch circuits fuses will be in the camper’s power center.
  14. BillyMc
    678
    274
    Mar 25, 2018
    Unless you have something high demand I guess 15 amps should handle the load. My fridge draws just over 9 amps when in 12 volt mode, but it has it's own inline fuse. My furnace draws 3.4 amps. Never checked the draw on the water pump, but it runs very little. All my lights are LED. Never checked the TV in 12 volt. Have four USB ports and 2 12v outlets. Ours had a 30 amp when we got it, but I dropped it to a 20 amp. The 20 amp has worked fine into the second season now.
  15. Nanapoppypops
    172
    Mar 30, 2019
    Makes sense. Thank you
  16. brwarrior
    brwarrior Active Member
    154
    65
    Mar 26, 2017
    Clovis, CA
    If you use 30A at the battery make sure the wire from the battery to the panel are #10 AWG or larger.
    BillyMc likes this.
  17. Nanapoppypops
    172
    Mar 30, 2019
    Not sure what that means. Originally it had a 15 fuse for the battery. The converter has all 15's and one 30 fuse.
  18. brwarrior
    154
    65
    Mar 26, 2017
    Clovis, CA
    #10 AWG is the size of the wire. It's required for a 30 amp fuse. #14 will work for 15A, however, the voltage drop at 12 volts and that small of wire is substantial.
  19. Nanapoppypops
    172
    Mar 30, 2019
    Okay, thank you
  20. WrkrBee
    WrkrBee Well-Known Member
    1,907
    710
    Makes no sense to have a 15 amp fuse at the battery and a larger 30 amp fuse in the converter.
    theseus likes this.
