Battery monitors, are they worth the investment?
Discussion in 'Boondocking' started by BillyMc, Sep 9, 2018.
  1. BillyMc
    BillyMc Active Member
    442
    136
    Mar 25, 2018
    Thinking of installing a battery monitor, but not sure if it worth the trouble and expense. I'm looking at a 30amp that the power use and charge goes through and a 50amp that samples with a shunt. There isn't a huge difference in price. The 50amp is a little more involved to install, but not really an issue. There is the issue of the monitor also using some battery power. I also have 12v power ports that I could just plug a volt meter in to check the voltage.
  2. Raycfe
    13,953
    943
    A simple voltmeter is all I use.
    Adam H likes this.
  3. Toedtoes
    Toedtoes Well-Known Member
    925
    586
    May 28, 2018
  4. joet
    3,663
    554
    A simple volt meter, and I use the charge controler
  5. Solo camper
    Solo camper Member
    66
    18
    Apr 23, 2018
    West virginia
    Best thing I did before my recent trip to Colorado was install digital volt meter with usb charging ports. I could tell exactly where I was on battery power. Even from my bed. I would recommend you do it.
    Tim Phillips and hometownhiker like this.
  6. hometownhiker
    hometownhiker Active Member
    433
    29
    Oct 17, 2009
    Franklin, NC
    Same here, works well for me.
  7. McFlyfi
    McFlyfi Active Member
    263
    88
    Aug 1, 2014
    Thousand Oaks CA
    A simple volt meter won't give you an accurate picture of your SOC, bit it will put you in the ballpark.
    I've spent a ton on my solar/battery monitor ( Trimetric SC 2030 and TM 2030RV), and I wouldn't be without them.
  8. tombiasi
    4,713
    537
    Any voltage monitor should have and accuracy of at least .01 volts. SOC is measured in tenths of volts. The meter should be capable of 1/10 of that. Many of those cheap plug in meters can't do that.
  9. McFlyfi
    263
    88
    Aug 1, 2014
    Thousand Oaks CA
    I'm not saying the meter can't measure the voltage correctly.
    What I am saying is that measuring the voltage is not an accurate
    gauge of a battery's state of charge.
  10. tombiasi
    4,713
    537
    I get that. But if you are going to rely on voltage at least it should be accurate.
  11. BillyMc
    442
    136
    Mar 25, 2018
    Well I check power demand for everything except the water pump and the total load is under 10amp. I have decided to go with the 30amp monitor.
  12. rourky80
    rourky80 New Member
    17
    Sep 13, 2016
    Upstate NY
    wireless head unit with shunt. I power the head unit with an old usb battery bank or usb inside the pup if i want.
    i also sit with it outside on table next to me during the day and watch the charging from my solar panels if i'm so inclined. Shows voltage, amps in and out, watts in and out and amp-hours, so that you have an accurate battery charge level (if you clear it when full). amphours go up and down based on usage and charging. If you reset it when battery is full, you can set the battery amphour size (which i set to my 50% level) and then the battery picture is relative to how much juice i have left before i hurt the battery. in the picture, the shunt and wireless is in the waterproof outdoor gang box attached at the back of the battery box. Was only $25 and fun to tinker with....
  13. lostboy
    lostboy Active Member
    170
    39
    Nov 13, 2016
    Lakeville, MN
    Are you saying the whole thing was $25, do you have a link to the product?
  14. BillyMc
    442
    136
    Mar 25, 2018
    They aren't very expensive. The 30amp I ordered is $19.50. The 50amp and higher use a shunt and start at $29.50 for the 50amp version.
  15. rourky80
    rourky80 New Member
    17
    Sep 13, 2016
    Upstate NY
  16. JimmyM
    JimmyM Well-Known Member
    2,011
    362
    Jun 5, 2014
    Franklin, MA
    Do you have the link for where you got that one?
  17. rourky80
    rourky80 New Member
    17
    Sep 13, 2016
    Upstate NY
  18. JimmyM
    2,011
    362
    Jun 5, 2014
    Franklin, MA
    Thanks.
  19. tenttrailer
    2,935
    207
    Jul 18, 2013
    Thornville, OH
    It all about what you need or toys to play with. We've been camping with campers for 30+ I have installed cheap voltmeters with monetary switch on the battery box and one with a momentary switch inside. It seems to do what we need for our extended dry camping. Inside I don't have to go outside to see what my charge is. On the battery box I can check the status of the battery when stored in the garage and know when to turn on the charger.
    A few years ago when I got a solar panel, I bought a monitor only for the solar panel. Kinda a toy to see how it's charging and adjust the angle to max it out.
  20. nineoaks2004
    5,830
    2,077
    Graceville, Florida
    I used a free multi meter from HF and took an old extension cord with the plug still attached,
    and soldered the leads from the meter to the cord I just set the meter upright and plug it in to the wall, works fine for me and cost nothing.
