Bed pole question
Discussion in 'PopOut (Hybrids)' started by mpotapa, Jun 24, 2018.
  1. mpotapa
    mpotapa Member
    510
    Mar 11, 2014
    My friend has a 2007 Starcraft Antigua I believe is what it’s called. He is confused about the bed poles. It appears they should go in the circle bracket pictured but when they are put in there the bed seems to be on too much of an angle. Any ideas?
  2. Raycfe
    14,534
    1,123
    What locks them in from moving? That would be where they should be placed.
  3. James Whelehon
    James Whelehon New Member
    Jun 30, 2018
    My TravelStar has the same set-up.His placement of the poles looks fine and the bed dropped down looks reasonably level.Has the whole trailer been leveled? Drop a level on the bed platform.I'm sure he knows the rear poles are completely different from the front,they don't lock together.
  4. SlavCo
    SlavCo Member
    54
    Mar 16, 2016
    I have the same setup and mine are on an angle just like his is, probably to prevent the pole from folding. The poles should be on an angle, even looks like that in the manual. 2016-07-17_181015821_94005_iOS.jpg
