Before I go BOOM!!!
Discussion in 'Propane - Got Gas' started by kateKamper, Jun 17, 2019.
  1. kateKamper
    kateKamper New Member
    Feb 17, 2019
    on top of the hill,Somerset county Pa.
    Hello All,
    I have a 1993 coleman Cape Cod that I have been working on I am trying to figure out if this is the correct way that the gas lines should be run. This is how it was put together when I bought the PUP. I know that I will be replacing the tank for sure. the first t off the tank goes to the curb side grill hook up which is HP. next is what I would assume is the HP regulator then the low pressure regulator that goes to the inside appliances. My question is should the HP line be hooked to the HP regulator?
  2. frolin
    frolin Member
    108
    May 13, 2013
    Should go tank into HP regulator then T to outside hook up and into LP regulator into inside lines.
  3. kateKamper
    Feb 17, 2019
    ok, but do those 2 regulators look like they will come apart?
  4. joet
    4,261
    764
    Looks like they come apart. They are mounted wrong. The vent must face downward
    nineoaks2004 likes this.
  5. kateKamper
    Feb 17, 2019
    thanks I will try and get them apart.
  6. rabird
    6,545
    247
    TX
    kateKamper, it is not normal for a dual stage RV regulator to come apart.
    93 cape cod parts book see page 26
    https://cdn.shopify.com/s/files/1/0..._four_seasons_series.pdf?16695232820753828628
    the original HP regulator was set to 16 psi for the outside stove (the stove was either a coleman stove or an unregulated stove that was regulated at the front cylinder to 16 psi). teed to outside then a single low pressure reg, These days they always use a dual stage RV regulator for low pressure.
    I wouldn't have any issue with full cylinder pressure to the outside HP port for your grill or any regulated appliance. Might always keep it off during travel! You might consider 20 or 30 psi regulator at the cylinder then tee off to the outside then to a dual stage RV regulator, this would limit what pressure the hose from the tee to the outside HP port 'sees'.
    All this stuff hanging off the cylinder gets heavy for the that black ACME nut @ the cylinder, these days they use a short pigtail from the cylinder to regulators that are mounted to something. You can see modern hookup via parts books like page 31 of 2010 americana series https://cdn.shopify.com/s/files/1/0273/4347/files/2010_Americana_Parts_Book.pdf?16695232820753828628
  7. kateKamper
    Feb 17, 2019
    I do have the original stove that goes outside and on the part that connects to the stove it says pre set non adjustable. Now my set up looks nothing at all like what is in the parts book page 26 that is why I was questioning if it was safe the way it is or should I just replace the whole dang thing.
  8. rabird
    6,545
    247
    TX
    I would not use the curb side port for an unregulated appliance! For a stove or grill that has a regulator is OK.
  9. SteveP
    SteveP Well-Known Member
    1,311
    312
    The high pressure stove that came with the old Colemans, did require a regulated feed, so I personally wouldn't try to use it at tank pressure. But most of the camp stoves made to use the 1 lb bottles, Coleman, Camp Chef, etc. would be safe to use because they have their own regulator. I run my Camp Chef Explorer off of the camper propane tanks using a propane tee between the tank and the regulator. Yes, I have an outside low pressure port, but I choose not to use it.
  10. kateKamper
    Feb 17, 2019
    Is this a regulator on the coleman quick connect that goes to the stove? It says pre-set non adjustable on the black cap. Resizer_15609952557251.jpg Resizer_15609952557253.jpg
  11. kateKamper
    Feb 17, 2019
    This is the set up the owners manual shows which is nothing like the set up that is on the pup right now. Resizer_15609969254480.jpg
  12. rabird
    6,545
    247
    TX
    Yes that is the regulator for a coleman stove, you can use it with your current system that has full container pressure going to the outside port or with little green bottles.
    New coleman stoves come with that exact same regulator/connector.
    Either connected to a cylinder with a hose or a green 1 lb bottle.
    kateKamper likes this.
  13. rabird
    6,545
    247
    TX
    Yes, that is original as shown in the parts book.
    Again, back then they used a 16 psi regulator then teed off to the outside port and then a low pressure regulator.
    Your current setup tees off before being regulated.
  14. rabird
    6,545
    247
    TX
    Previously I stated you had an ACME connector at the cylinder, now that I looked closer at your original pics, it an ole style POL with left hand threads, turn to the right to loosen.
  15. kateKamper
    Feb 17, 2019
    rabird, Thanks a lot for you help. I am thinking of replacing the whole thing.
