Bike Rack Recommendation
Discussion in 'Cargo Carriers / Bike Racks / Other Storage Option' started by SongCamper, May 7, 2019.
  1. SongCamper
    SongCamper Active Member
    105
    45
    Jul 4, 2017
    Nashville
    I've got a Rockwood 2516G and we'd like to be able to take 1-3 bikes with us. Does anyone have a bike rack and love it? Any recommendations?
  2. jmkay1
    4,426
    1,366
    This is almost the best bike rack for a popup camper. As it attaches to the a frame of your camper and less likely to get in the way of your hitch. Downside is it's expensive.
    Pro Rac Systems Inc. Tent Trailer 4 - Bike Carrier https://www.amazon.com/dp/B000V2KN22/ref=cm_sw_r_cp_apa_i_7FI0CbK7WRAN1
    I personally only have a couple bikes and fortunate my bikes for the most part don't get too much in the way of my hitch I can get away with using a hatch back bike rack. Not many can though.
    Hoser, myride and SongCamper like this.
  3. tfischer
    tfischer Well-Known Member
    3,318
    843
    May 21, 2014
    We have one that I think is no longer made... I got it off of Craigslist. Closest thing made to day is the Sixnall which I think would be a good option. We just ratchet strap ours down to the camper frame... ours holds four bikes, we started with 2 adult bikes, a 20" boys bike and a smaller boy's bike, and now we carry 4 adult bikes.
    I definitely did not want something where you have to remove the wheel to carry the bike. When we carried boy's bikes that would have required a wrench even.
    SongCamper likes this.
  4. bheff
    bheff Active Member
    403
    134
    Feb 24, 2011
    NW Arkansas
    Hands down the best bike rack out there is the 1Up. All aluminum, zero plastic fits a huge range of bikes and is crazy stable.
  5. myride
    myride Well-Known Member
    810
    366
    May 14, 2015
    Edmonton, AB
    ProRac. ...hands down
  6. tfischer
    3,318
    843
    May 21, 2014
    Not sure it's quite that cut and dry lol
  7. benandbobbi
    benandbobbi Member
    162
    Dec 18, 2012
  8. PoPuP Pistol
    PoPuP Pistol New Member
    Aug 22, 2018
    I tried putting a rear hitch on my Fleetwood Tacoma with the normal hitch rack and two small kids bikes. I thought I might still have enough tongue weight but not so. Trailer sway was bad.
    So I wouldn't recommend that.
    SongCamper and LittleBrother like this.
  9. davido
    davido Active Member
    866
    162
    Jul 17, 2014
    I have that same trailer, and installed a SportRack SR1020 on it. They sell for around $150. Once you get it installed, it is very sturdy. However, I did have to visit the hardware to get better through-bolts and washers for the clamps that hold the crossbars on the pillars. No big deal; $5 bucks.
    On this rack I've installed four fork-mount bike racks, and have easily carried those four bikes. A couple times I've used it for carrying a kayak and a couple bikes.
    Its advertised capacity is 200 pounds, evenly distributed. So unless you're carrying four eBikes, it's as strong as you could ever need.
    When installing it, I found it useful to seal all the way around the pillars with silicon to thwart moisture intrusion. Literally, an ounce of prevention. ;)
    My trailer has an air conditioner installed, so I put the racks toward the forward part of the roof. I seem to recall mounting the first crossbar about thirteen inches aft of the front of the roof, and the second crossbar about 33 or 34 inches behind the first one. I set the distance between the crossbars to be the same as the distance I have my cars' crossbars at. That spacing works with my bike racks and also with my car top cargo carrier.
  10. ezakoske
    ezakoske Active Member
    502
    57
    Nov 30, 2014
    Escondido, CA
    I've been looking for a sixnall - looks like they are out of business....
  11. LittleBrother
    LittleBrother New Member
    Feb 1, 2017
    Glenn Dale. MD
    I was considering the Pro-Rac as the only option for me until I found the Lippert Jack-It bike rack. Only holds two bikes, but it's with the wheels on and they now have an adapter to use the rack in your 2" receiver so you can load the bikes directly on the TV after you get to camp. Selling on Amazon right now for about $200. Only drawback I see is your tongue jack can't have a top (vertical) handle; need a motorized or front-mount (horizontal) crank.
