Black box with wires?
Discussion in 'Mystery Parts' started by ValGo, Jun 12, 2019.
  1. ValGo
    ValGo New Member
    Jun 12, 2019
    Hi! I have a black rectangular box located within the wires, between my battery and my trailer. All of the wires enter and exit it. I tried to attach a picture, but apparently the picture is too large to upload. What is it? And what is it’s purpose? I have a Rockwood Freedom Premier 2514G. Thank you!
  2. RESTLS
    RESTLS New Member
    Jun 12, 2019
    Urbandale IA
    Without a picture, your description sounds like the electric emergency brake box. There should be a black or red plastic rod in one end of the box with a hole in the rod. This rod should be connected to a cable that connects to your hitch or vehicle. In the event the trailer comes unhooked, the cable pulls the rod and activates the trailers emergency braking system through the wires connected to the battery and the brakes.
    2004 F150 Supercrew
    2004 Fleetwood Carmel
  3. jmkay1
    4,409
    1,343
    Can't help you with from your description. However if you download an app called resize or something similar, you can resize the photo you took so you can upload it here.
    ValGo and kitphantom like this.
  4. WrkrBee
    WrkrBee Well-Known Member
    1,896
    703
    Sounds like a junction box. Have you opened it?
  5. ValGo
    ValGo New Member
    Jun 12, 2019
    It is not the emergency brake. That I do know. This one is different and almost looks like a junction box as all the wires enter and exit from it. But no, I haven’t opened it because I can’t seem to get it to come apart. I will try again to upload a picture.
  6. ValGo
    ValGo New Member
    Jun 12, 2019
    015F9A91-E3D5-4E4A-984A-BE85A88AB4FD.jpeg 1E470E92-934A-446E-A0E6-9D3ABC0E83DD.jpeg
  7. bheff
    bheff Active Member
    387
    125
    Feb 24, 2011
    NW Arkansas
    That is just where the trailer plug wires meet the trailer wires. No need to take it apart
    neighbormike, nineoaks2004 and ValGo like this.
  8. Ourkid2000
    Ourkid2000 New Member
    Aug 14, 2018
    Nova Scotia
    Handy little place for testing voltages if you have troubles. Just pull apart a little and you can get at all the connections with a meter.
    neighbormike likes this.
  9. rabird
    6,537
    244
    TX
    I assume this is some sort of pigtail that was added to change the 6 way 'square' connector to either 4 flat or standard 7 blade at the front of the trailer.
    something like
    Item Number: 40047 or Item Number: 30041
    http://www.rvpigtails.com/ProductList?ProductTypeId=1
  10. Anthony Hitchings
    283
    93
    Mar 2, 2019
    Which is exactly what I have at the moment.
