Black rubber tip for umbrella Pole
Discussion in 'Miscellaneous Repairs & Maintenance' started by Indianrock, May 23, 2019.
  1. Indianrock
    Indianrock Member
    111
    Feb 25, 2012
    Has anyone managed to make a homemade black plastic tip for the support poles that run horizontally across the roof of your tent trailer bedrooms ....this is for a Coleman
    https://drive.google.com/file/d/1Hi4gCALmATVRDIF1FX0QCbptiPwJMYdJ/view?usp=drivesdk
  2. GreyFox
    GreyFox Well-Known Member
    886
    388
    Oct 10, 2018
    S Ontario
    I did, back in 2005, and still use these modified poles to support the ends of the awning we have hanging over the back deck on the house. Not plastic though as they'd just break again - used metal.
    megcabra likes this.
  3. PopUpSteve
    PopUpSteve Administrator
    18,370
    1,268
    Dec 22, 2002
    Malvern, PA
  4. Indianrock
    Indianrock Member
    111
    Feb 25, 2012
    I ordered a couple from ColemanpopupParts but may look into making the home-made variety. Thanks.
  5. GrueMaster
    GrueMaster Active Member
    157
    49
    May 22, 2013
    Saint Helens, Oregon
    I have designed and 3D printed my own. You can see it here. I printed mine in PLA and it is still going strong, but if you can print ABS, it would probably be better.
    Why buy one for $5 when you can buy a $600 3D printer and spend hours designing and printing your own? Much more fun this way. :p
    And I see you live in Bellingham. My hometown. I'll be up that way in June (21-23).
  6. Indianrock
    Indianrock Member
    111
    Feb 25, 2012
  7. Indianrock
    Indianrock Member
    111
    Feb 25, 2012
    Is this the brass nipple you used, more or less? If so you also used a wood screw about 1.75 to 2 inches long?
    Anderson Metals 56112 Brass Pipe Fitting, Close Nipple, 3/8" NPT Male, 1" Length
    https://www.amazon.com/Anderson-Met...ass+nipple&qid=1558716980&s=industrial&sr=1-4
  8. GreyFox
    886
    388
    Oct 10, 2018
    S Ontario
    Yeah, 'though mine was 3/4" long, about the same as the original plastic tip. We're talking 14 yrs ago so I don't really recall how long the screw was - doesn't matter much as long as the head is large enough to capture this adapter.
  9. Indianrock
    Indianrock Member
    111
    Feb 25, 2012
    Ok what was delivered to me is too large to fit. The hole in the bed roof support is 1/4 inch diameter. So the 3/8 inch NPT fitting I got is probably more like 5/8 inch diameter.(see below )
    This "barb to NPT" fitting might work.
    1/4" Barb x 1/4" NPT Male Pipe
    https://amzn.to/2MaKP8C
    "As a general “rule of thumb” an NPT thread is approximately 1/4″ (0.25”) larger than its “name.”
    https://blog.restek.com/?p=47867
