Black tank spilled on concrete in garage - HELP PLEASE!
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by Kati "Chirp" Blackledge, Dec 1, 2018.
  1. Kati "Chirp" Blackledge
    Kati "Chirp" Blackledge New Member
    Dec 1, 2018
    South Orange County, California
    OH MY GOSH, just an hour ago, my husband, a plumber, of all things, went to dump the black tank into a bucket. The force was way harder and faster than he expected, and it splashed a lot onto the floor around the bucket. The stench is beyond unbelievable. Anyway, I used a trick I have used before - baking soda with vinegar. We covered the area. Let it sit, and now after he has mopped it up, it still stinks very badly. WHAT, if anything, have you done to alleviate the stench? He tried Simple Green, too. That didn't work at all. I think he is going to have to take the trailer out, power wash the floor, but there has to be something else...???Please help me help him. He is so bummed.
    BTW, I don't think this is the correct category, but I couldn't find one that was like what I wanted... I saw the word Blunders and that brought me here. I am looking to see if I can find a better place to post this to get some help.
    HappyTraveler and PopUpSteve like this.
  2. WrkrBee
    WrkrBee Well-Known Member
    1,898
    703
    I find mortar mix soaks up stuff quick. Just keep pushing it around to keep fresh mix on the spill. If it just sits there, it can harden and then has to be scrapped up.
    HappyTraveler likes this.
  3. xxxapache
    2,738
    754
    Bleach solution and a day or two of open air
    HappyTraveler and BillyMc like this.
  4. joet
    4,250
    752
    X2
  5. Kati "Chirp" Blackledge
    Dec 1, 2018
    OK so we just now put like a gallon of straight simple green and let it sit, (he says thats what they use to clean up hazmat sites at work) and its been power washed with hot and cold water. I can still smell it - that concrete unsealed 50 year old garage floor soaked it up fast! OK next we will try bleach solution. Thanks. That mortar mix sounds interesting too. I will tell him about both. Thanks so much. I can't believe it's my first day on this board and this happens. We have had toy haulers and trailers and motorhomes for 20 years and he has NEVER had this happen. Such a drag.
  6. Haybale
    2,477
    295
    Aug 22, 2013
    San Diego via MN
    Was the tank sitting for a while with 'substance' in it?
    Do you use any chemicals in the black tank to help break things down from use to dump?
    And best bet is bleach water and let it sit. Ensure you get all the walls and any other splatter spots.
    An odor absorbing cat litter worked into the cement may help get rid of anything left in the cracks and such.
  7. jmkay1
    4,411
    1,345
    I'm with the others of bleach and airing out. Between two dogs and cats I get some pretty ugly messes and a bleach solution and airing out does wonders. Good luck. I can only imagine what that must smell like.
  8. tenttrailer
    3,105
    272
    Jul 18, 2013
    Thornville, OH
    Same thing happen to me years ago, but outside and it was not just on the drive. I was standing behind the bucket in line with the flow.
    I would get the hose and spray it out of the garage. I would than use a laundry soap like tide and scrub the floor with a push broom and water and rinse off the floor. Once it is out of the garage keep deluting with water you should get it under control.
  9. TRR
    TRR Active Member
    443
    216
    Nov 3, 2014
    Alabama USA
    HappyTraveler and neighbormike like this.
  10. GreyFox
    GreyFox Well-Known Member
    966
    436
    Oct 10, 2018
    S Ontario
    I can't help you with the stench but if you're going to be emptying your black tank at home on a regular basis the solution isn't to simply dump it into a bucket but to use a waste macerator and pump out the macerated contents of the black tank. You can direct that macerated black water to a downstairs toilet or if you plan to do this frequently DIY an intake stack into your house sewer stack - which ought to be an easy task considering your DH is a plumber. A series of pics illustrating my own setup is here ...
    https://photos.google.com/share/AF1...?key=YTZrWHhLU0VrOWFnakV4el9jMXJodi1ISVItaGFR
  11. Wrenchgear
    3,192
    495
    Aug 5, 2010
    5 Star Eagle Camper
    Give it few days, the smell will go away. You've thrown enough different stuff on there to kill any smell. Leave the doors open and it will all clear out. Here's a link that may help.
    www.youtube.com/watch?v=BeskbiJjCXI
    HappyTraveler and kcsa75 like this.
  12. nhlakes
    nhlakes Well-Known Member
    643
    317
    Oct 15, 2011
    DE and NH
    I'd also get an industrial fan and blow it low over the area and toward the open door.
  13. tenttrailer
    3,105
    272
    Jul 18, 2013
    Thornville, OH
    I know some people put in a drain pipe to their septic tank for their rv.
