Black water tank treatment
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by Fixitup, Jul 10, 2018.
  1. Fixitup
    Fixitup Active Member
    332
    156
    Jun 7, 2016
    So I know this is not a pleasant topic.
    We have been at the camping thing for many years. Have always used the chemical treaments. On this trip (10 days) and our spring break week trip we used a quart of bleach per full tank. Much cheaper than the chemical and had no odor or issues. Thoughts on this good or bad? Thanks.
  2. Toedtoes
    Toedtoes Well-Known Member
    938
    592
    May 28, 2018
    I don't use any treatment and have no odor issues.
    The only issue I could see with adding bleach is that it could cause deterioration of the rubber gaskets on the valve. You might try using chlorine granules instead - they are less abrasive as they are meant for pools and hot tubs. You could also try simple baking powder.
    Fixitup likes this.
  3. Fixitup
    332
    156
    Jun 7, 2016
    The effect on gaskets makes complete sense. Thanks for the advice. I will give the suggestion a try.
