Blinking red led, heat does not work correctly.
Discussion in 'Heating / Cooling Systems' started by fordfixer68, Dec 9, 2018.
  1. fordfixer68
    fordfixer68 New Member
    Apr 27, 2016
    I have recently purchased a 2010 coleman Utah. It has a factory installed Atwood heater, model 7916-II. The problem is, if i take the cover off and hold the reset button, the heater works perfectly. As soon as I let go of the button, the heater kicks off and blinking red led comes on 1 blink every 3 seconds or so. Any ideas, did not see any exhaust restrictions etc.. Possible sail switch concern. Any help would be greatly appreciated.
  2. Snow
    9,720
    801
    Your best bet would be to find a manual for your furnace.. Most times they can be found on the furnace manufacturer website..
  3. xvz12
    xvz12 Well-Known Member
    755
    389
    Apr 6, 2017
    New Plymouth, ID
    You can download the service manual for your furnace( & several other models) from <HERE> Hope it helps.
  4. Sjm9911
    3,392
    1,591
