Bonair 1989 manual needed
Discussion in 'Camper Manufacturers & Manuals' started by Kyle bonair 1989, Jun 17, 2018.
  1. Kyle bonair 1989
    Kyle bonair 1989 New Member
    Jun 17, 2018
    Hey there
    I just purchased a 1989 Bonair (BA 1200) pop up trailer but it didn’t come with a manual.. I need help with how to hook up AND where to hook up a 12v battery to run the lights and fridge because i don’t want to use propane
    Thanks in advance !
  2. DJS12354
    DJS12354 Well-Known Member
  3. Kyle bonair 1989
    Jun 17, 2018
  4. Kyle bonair 1989
    Jun 17, 2018
    It worked ... but all those instructions tell me is how to raise and lower the camper... it doesn’t tell me anything about how to hook up a battery for the lights and fridge .... any other options ??
  5. Snow
    9,349
    617
    Fridge will kill a battery in a few hours .. it is better off to run the fridge on propane and 120vac .. First you need to discover if you have a 2 way or 3 way fridge ..
    Battery for lights is pretty straight forward and easy ..
  6. Arruba
    Arruba Active Member
    239
    59
    Nov 28, 2014
    Central Oregon
    Not to be insulting, did it come with a battery originally? Some of the older, smaller ones, like the Coleman Columbia and my Ltl Gasser did not. My Gasser had a little plug in jack on the street side to plug in a jumper cable to the tow rig battery. If it has been converted to use a battery, the cables are usually ran to either the tongue or the cabinet nearest the converter.
    Good Luck
  7. Kyle bonair 1989
    Jun 17, 2018
    As for the 2 way or 3 way, I’ll find that out tonight when I look at it after work... but I do have a solar panel attached to the battery so it stays fully charged ... but I don’t see a connecting plug for a battery anywhere... usually there is a battery box at the front of most campers but this one doesn’t have one at the front where the propane tank is .... still searching...
