Bracing needed for Roof A/C
Discussion in 'Heating / Cooling Systems' started by wmshay6, Jul 20, 2018.
  1. wmshay6
    wmshay6 Member
    101
    Jul 6, 2011
    I am wanting to add roof A/C to my Fleetwood Graphite. (10' box, 2 piece AL Roof). I have looked around quite a bit and can't find an answer . . . I have a roof brace installed already- mid-roof in front of where A/C would mount. It has holes for power cord.
    Do I need a second roof brace in my roof? The parts site lists two different braces available and the brace kit comes with two braces which leads me to believe that two braces are needed.
    I have dealer installed Yakima rails up front, so maybe original brace was added when rails were added to the roof? not sure. if I only need one brace, I'm all set. but not sure that's enough. Can anybody say for sure that owns a Fleetwood / Coleman?
  2. TRR
    TRR Active Member
    443
    215
    Nov 3, 2014
    Alabama USA
    My Fleetwood Taos (8' box, aluminum roof) had a rooftop a/c on it when I bought it used but no brace. The roof was starting to sag a little. I added one brace in front of the a/c, pushing the roof back up as I installed it. It's been fine ever since.
  3. Sjm9911
    3,315
    1,549
    My Coleman Westlake only has one a.c. brace. It seams ok, it's a 2000
  4. BillyMc
    BillyMc Well-Known Member
    623
    252
    Mar 25, 2018
    My Starcraft has two.
