brake/signals work, but no tail lights or side lights
Discussion in 'Wiring' started by chrisarrick, Jun 5, 2018.
  1. chrisarrick
    chrisarrick Member
    77
    26
    Oct 10, 2017
    North Central Indiana
    Hi all, This past weekend I was able to get out for a night in my new to me 84 jayco 1008. Last fall all of my lights worked fine. But now, all I have are brake lights and turn signals in the rear. So, I can travel during the day but never at night. I have checked, re-checked and triple checked that the wiring was the same at the harness as last fall and have searched here and the web for jayco wiring and it really does seem I have it correct. A rodent chewing wires in the camper is most suspect, of course.
    I have no idea where to start looking next. I am in no way very handy with electrics, very basic skills, but it seems I have voltage where I need it, I have a good ground. Is there a good first place to start checking and how do I test for continuity if needed?
    Another question, and I hope it's not a dumb one, but I'll ask anyway... Are these lights like Christmas tree lights? Meaning if bulbs are out will they all be out?
    Thank you much for insight!!
    Chris
  2. eoleson1
    eoleson1 Well-Known Member
    1,513
    208
    Jul 5, 2011
    Macomb County Michigan
    I'll answer your last question first: No. They are wired in parallel, so if one goes out, the rest will continue to work.
    To diagnose your issue, I would start by checking the tow vehicle (TV) wiring. Make sure you have 12V on the brown wire when the running lights are on. If you do, then move on to the trailer. Check for 12V at each of the light sockets with the TV connected to the trailer and the running lights on. Verify that you have continuity to ground between the TV and the trailer, and from the sockets to the trailer.
    chrisarrick likes this.
  3. chrisarrick
    chrisarrick Member
    77
    26
    Oct 10, 2017
    Thanks!
  4. jnc
    My money is on it being a bad ground on the pup.
  5. roybraddy
    roybraddy Well-Known Member
    1,548
    389
    Mar 23, 2016
    King George, Virginia
    X2 of starting at the source which is the truck 7-way receptacle.
    I use one of these 7-way circuit tester (AMAZON) and if all of the small LEDs work normally using this unit plugged into the 7-way receptacle then your trailer brakes and lights are normal leaving your truck. Knowing you are good at the truck 7-way receptacle speeds up things finding your DOT Safety Light problem.
    Google image
    The 4-way TEST module looks like this
    Google image
    Keep in mind none the DOT SAFETY LIGHTS are fed by anything on your trailer side.
    The 12VDc DC required for the SAFETY lights are all powered by the truck side 12VDc Start battery... I think all of my circuits are protected by a ATC fuse in one of my truck three fuse panels. Check your truck manual for this info.
    The only minor problems I have sometimes with the DOT Safety lights being intermittent are due to dirt or grim inside the truck receptacle. Since I always seem to have a can of WD40 and some DUCT TAPE in my truck door storage I usually spray a little WD40 into the truck 7-way connector and wiggle it all around when connecting up to the trailer... This cleans the actual connections somewhat. A better thing to use would be to clean the connections with something called Dielectric Grease...
    A good place to look at typical wiring diagrams of the DOT Brake and light wiring is ETRAILER.com on the internet... For me they are main go to internet source for everything trailer... Lots of great info on their site and a also a great source for trailer lights etc...
    Also note a loose ground connection between the truck and trailer really does strange things to the DOT Safety Lights operations...
    Roy Ken
  6. chrisarrick
    chrisarrick Member
    77
    26
    Oct 10, 2017
    I have power from the trucks receptacle but not at the end of the harness that plugs into trailer frame female socket (for tail lights). I try to jumper those & still don’t have tail lights. A white ground wire turns into a black ground wire. The yellow wire on the male side trailer harness is snipped (came that way) but I have a yellow wire that connects to white wire at each tail light. what the absolute hell is going on??!! These are factory connections, mind you. etrailer site says that the yellow & Black wires are not determined or used for something else. As far as I can tell there is no wiring for reverse.
  7. chrisarrick
    chrisarrick Member
    77
    26
    Oct 10, 2017
    What I found online for Jayco wiring:
    Green-tail lights
    White-ground
    Red-left turn & brake
    Brown-right turn & brake
    So in my case if I connect ground to ground and brown (truck harness) to green (camper harness) I should have tail lights.
    I assume the side lamps turn on with head/tail lights. At least they did last fall.
  8. Katskamper
    Katskamper Active Member
    479
    90
    Nov 21, 2015
    Fort Worth, TX
    is there any tool you dont own? you always provide informative answers& instructions!
    jnc likes this.
  9. nineoaks2004
    4,324
    1,215
    Graceville, Florida
    swap the brown and green, green should be turn signals which is also running lights
  10. tombiasi
    4,452
    357
    Well you need power at the end of your harness. Check the harness. Why go checking everything else when you are not feeding the trailer?
  11. chrisarrick
    chrisarrick Member
    77
    26
    Oct 10, 2017
    Again, thanks to all for info/help. I know this is an old thread now, but other work around the farm keeps getting in the way of the fun things I want to do!
    I have finally solved the problem, there were 2 problems actually. A problem with the jayco wiring harness connector in the trailer tongue and a bad/rusty ground. I bypassed the square connector in the tongue and ran jumpers from the 4 pin and I got tail lights, side markers, brake lights and signals. I even got them all at once! Haha! Thanks all!
    MaxedOut likes this.
  12. jnc
    That's what happens when you as old as Dirt.[:D][B)]
  13. jnc
    We have a Winner.[:D]
