Can a manual e-brake be added to my trailer??
Discussion in 'Tires / Brakes / Bearings / Axles' started by Twitchrider, May 21, 2018.
  1. Twitchrider
    Twitchrider New Member
    18
    May 27, 2017
    Hello,
    Trailers from Australia & South Africa have manual e-brakes. Simply pull the lever and the drum brakes hold the trailer in place.
    I am wondering if it possible to modify my pop-up so that it has a manual e-brake?? Pls let me know.
    Thx,
    Q
  2. Raycfe
    13,893
    921
    You would have to get backing plates with a manual e brake cable fitment and some kind of control.
  3. CampStewart
    CampStewart Member
    63
    33
    Nov 3, 2017
    You can buy brake assemblies with built in cable operated parking brakes. I would look at Etrailer
  4. jnc
    If you have a Trailer brake controller it should have a manual lever for the trailer brakes. Or if you have a breakaway switch and a battery hooked you just pull the pin and the brakes are locked.
  5. joet
    3,569
    522
    This would work until. The magnets burn up. Or the battery goes dead
    soft 17, Snow and Fless like this.
  6. jnc
    At least you wont be driving around with the Parking Brake on.
