Can Mr. Buddy Portable be trusted above 8000 ft.?
Discussion in 'Heating / Cooling Systems' started by Merlin14, Feb 28, 2019.
  1. Merlin14
    Merlin14 Member
    511
    Aug 30, 2014
    Asking this in a couple places:
    We will be camping above 9000 ft this summer. Heating with Mr.Buddy Portable.
    Owner's Manual says:
    Caution: When operating the heater at altitudes over 7,000 FT above sea level the heater may shut off.
    Have any of you had personal experience and what was it? Did heater work or shut off?
    TIA
  2. Sjm9911
    3,315
    1,549
    It probably has a o2 sensor on it , so less oxygen up higher. It senses the change and shuts off. I think wheather or not it shuts off depends on the make up air and oxygen content of the room. If it says it will not work, i would belive them.
  3. PopUpSteve
    PopUpSteve Administrator
    18,379
    1,273
    Dec 22, 2002
    Malvern, PA
    The reason for this is the oxygen sensor safety shutoff. Not advisable to try to override.
  4. tenttrailer
    3,079
    254
    Jul 18, 2013
    Thornville, OH
    NO! I would not if the manufacturer indicates in there spec not to use above a certain elevation. I think my Mr Heater has a 7,000 elevation limit, I would give it a 500 to 1,00 margin of error and not use it above 6,000 ft.
    Will it produce heat, Yes. But it will not burn as clean because of the lower oxygen level, and it will produce more poisonous gases than below the elevation specified. I'm sure the manufacture would love to have higher elevations listed in its specs for increase sales. But their engineers know it's not safe above certin elevations.
    BillyMc likes this.
