Can you heat / cool a pop-up effectively?
Discussion in 'Heating / Cooling Systems' started by cv7713, Feb 8, 2010.
  1. Yar
    Yar Garland, TX
    165
    Apr 13, 2008
    Garland, TX
    Our camper uses the heat strips and kept us toasty in Illinois last year with temps in the lower 30's. We didn't have the gizmos then but have them now. I'm looking forward to trying those out this weekend and see if the heater keeps us even warmer.
  2. Sub1ime14
    Sub1ime14 Member
    242
    Apr 1, 2008
    All great advice so far, but I noticed 2 good things that weren't mentioned yet:
    1. If you can't afford (or are stubborn like me) solar covers, a blanket, some bungee cords, and a tarp will do the job (tarp on top of blanket, of course... try not to use an extraordinarily heavy blanket, so you aren't weighing down your canvas).
    2. Electric blankets! A single-element electric blanket uses roughly 200 watts, versus a space heater that uses 1000-1500 watts. Even with temps in the 40s, a well-tucked electric blanket will keep you nice and toasty.
    Now, if you want your whole camper warm, go with a Mr. Buddy heater. They work miracles with a very reasonably small amount of propane! Just be sure to get an adapter hose to run it directly from the tank. Those little 1-lb tanks won't last you the whole night.
  3. cv7713
    cv7713 I'd rather be Camping
    25
    Feb 8, 2010
    Those who have the Buddy, is it the regular size Buddy? (or the Little Buddy or Big Buddy?)
  4. barbjmj
    barbjmj Member
    617
    Aug 28, 2009
    Mid-Willamette Valley, Oregon
    Good question. I tried searching Mr. Buddy and only come up with "Mr. Heater Portable Buddy Heater
    $79.99 - Cabela's. An easy-start button sets at your choice of a 4,000- or 9,000-BTU output." Is this what everyone is posting about?
  5. rmance
    rmance Member
    35
    Jul 12, 2009
    Canyon Country, California
    The A/C on my pup cranks! But, you have to be plugged into AC which is usually not the way I like to camp. But yes, it will keep you nice & cool. The coldest I have camped in is -6 degrees. The furnace ran all night long and kept the pup at a very comfortable temp ... T-shirt'able. And I can tell you, it will go through most of the battery and the propane will last you two nights. I do carry a couple of tanks and a spare battery. If you're plugged into AC you're set ... electric heater and electric blankets.
    I was in Zion one time with the temp at 17 degrees and the propane hose broke. Couldn't find a hose but did buy an electric heater at Walmart ... BWA HA HA ... it was like trying to cook a turkey with a flip'n match!
  6. Mr. Bill
    Mr. Bill PUP-2002 Flagstaff 725D TV- 2004 Dodge Ram 1500
    622
    Apr 27, 2009
    Geneva, OH
    We have found that no matter what time of year, having mattress heaters is a good idea. I used the propane heater a couple of times but had it set about 50 so it didn't come on but a couple of times. We use a small ceramic heater in the breezeway during the winter to pull the chill out of the air before coming in the house. I will bring it with us. We haven't camped during the school year so generally the days are warm and night cool when we start camping in the late spring and same in late summer early fall. Because DW and I have sleep apnea we need to have sights with electricity (we do have a marine battery for emergencies) and water. Sometime, I want to try boon docking but it may be hard with DW.
  7. Sub1ime14
    Sub1ime14 Member
    242
    Apr 1, 2008
    In my case, it's the Little Buddy. Works wonders!
  8. bud121156
    bud121156 Western North Carolina
    4,632
    25
    Apr 15, 2007
    North Carolina
    From the tests I have done in the shop and here in the house during power outages, I cant imagine needing to run the Big Buddy on the 18,000BTU setting in a pup!
  9. Flyfisherman
    Flyfisherman New Member
    3,682
    Mar 4, 2003
    Shallotte, North Carolina
    It's what I have, the regular Mr.Buddy ~ Click Here
  10. PopUpSteve
    PopUpSteve Administrator
    18,419
    1,291
    Dec 22, 2002
    Malvern, PA
    I have the two bottle Big Buddy. When I have had to use it in the camper (the camper's battery was dead and no other power source was available), I only had it on low and I was fine. It's better to had the extra BTUs if needed. I like to think that most of my camping gear can be used at home as well for emergencies, so that's why I have the extra BTUs.
  11. Rustyk
    Rustyk New Member
    477
    Jun 20, 2008
    Pa.
    We have a big buddy and have been out in some temps that we were glad we had the whole 18,000 btu's. As for the summer we use an old fashion hassock fan. It really does a great job of keeping the air circulated and moving. We camp at OC. MD. in August every year and have never had any problem with the pup being too hot..
  12. Okiejayco
    Okiejayco New Member
    May 11, 2009
    Yes you can keep a pop-up comfortable. We have a '93 Jayco Cardinal, which is about 16 feet long without the bunks. I put the reflectix mod in the ends only, Cabelas survival blankets on the tops of the bunks, and carpet runner on the floor. We just camped when it was 20 deg out. We kept it in 65-72 deg range easily with 2 elec. heaters, neither cranked all the way up. Set the propane furnace at 62, it never came on. I am positve in the summer, she would stay cool, we have camped in the 85-90 deg range and kept cool, without the above mods. If anything make some reflectix for the windows in the main body (though you look a little like an ufo if you do this) Park under trees, I think you would be fine, without the main body reflectix. We spent less than $80 for the mods.
  13. Unstable_Tripod
    14,279
    22
    May 20, 2008
    Seattle, Washington
    I know there are people who sleep with a WAVE or Mr. Buddy running but I wouldn't. All Mr. Buddy heaters have a yellow label on the box that says, "Do not operate heater while sleeping."
  14. Sub1ime14
    Sub1ime14 Member
    242
    Apr 1, 2008
    I always, always, ALWAYS have the Carbon Monoxide detector on, and I check it often to be sure the levels don't get above a very minimal number (10 or 20). Usually, it's right around 0 to 5. I would never recommend letting a Buddy Heater run without having a CO detector in your camper (a loud one, so it'll wake you). Also, be sure it's stable and won't be knocked over. In addition, crack two opposite window corners to allow for a bit of fresh air circulation. PUPs are pretty drafty as-is, but this is a good safety precaution. I've never had even a minor problem with all of these things in place.
  15. JulesCamper
    JulesCamper Indianapolis, IN
    423
    Aug 12, 2008
    Indianapolis, IN
    I do not have A/C but have carried electric fans and it seems to move the air in the summer( I like naps after lunch)I have a ceramic heater with a thermostat that I use in the winter. At night I crawled in my sleeping bag and was toasty all night. I really prefer to camp in the spring summer and fall months
  16. BuxCamper
    BuxCamper Member
    318
    Mar 29, 2003
    Bucks County, PA
    It isn't so much generating heat or cold in a PU its retaining. All of the tricks mentioned in this thread are important if you want to have any chance to maintain the temperature.
  17. Luv2ridebikes
    Luv2ridebikes New Member
    1,942
    Apr 17, 2005
    Granger, IN
    We use heat strip first, furnace second for reasons already stated. The heat strip seems to hold about a 15 degree differential unless it is extremely windy or people (kids) are going in and out constantly. We camp down into the low 40's at night with just the heat strip.
  18. TnDrew
    TnDrew New Member
    196
    Feb 9, 2010
    Are the heat strips as effective as an electric ceramic heater?
  19. bpolwort
    bpolwort Member
    124
    Jan 24, 2010
    I have no problem keeping the PUP as cool as I want at night with the A/C, it will freese you out if you want it too. During the day it will only keep in about 80, while in the sun without Gizmos. As to the winter, I bought my PUP without a heater. I run 2 electric quarts heaters and they will keep it pretty warm. I have camped in temps down to 8 degrees F, and it would be cool in the camper, but not cold. The thing you have to realize is that camping in a PUP is a blend between truly roughing it and living with the comforts of home. If you love to camp, you will love a PUP.
  20. Wizfisher
    Wizfisher New Member
    1,271
    Mar 5, 2009
    While camping at a State Park the last couple nights in Central Florida the temps at night got down into the mid 30's. The first night I did not run the furnace and woke up freezing. The second night I ran the furnace and kept the pup at 65 degrees with no problems. It didn't run too much either.
    I don't have reflectix, or any of the other heat retaining mods.
