Cant get trailer tow lights to work?
Discussion in 'Tow Vehicles, Hitch & Towing' started by WinHac, Jul 9, 2018.
  1. WinHac
    WinHac New Member
    29
    Nov 30, 2016
    I have a 4pin harness on my car and a 7? pin on my camper The connector does fit in the bottom but nothing works. Am I missing a pin on the bottom row on my camper? Or do I need an adapter cable if so can some one link me to it?[​IMG] [​IMG]https://www.dropbox.com/s/fz2jwt5ir29a97c/IMG_1125.jpg?dl=0
    https://www.dropbox.com/s/zlyrkcn8gippzuu/IMG_1124.jpg?dl=0
  2. neighbormike
    1,507
    780
    Oct 6, 2012
    WI
    Not 100% on this, but the tv connector will not plug into that socket... there should be a camper-specific harness to plug into the tongue and the other end will be either 4-flat or 7-round. You may end up having to determine which pin is which and wire-up your own harness.
  3. jnc
    Yup you need to have some new wiring installed. Uhaul can usually do this but I think you may need to change both TV & Camper plugs.
  4. WinHac
    WinHac New Member
    29
    Nov 30, 2016
    I got a 4 wire harness put on thanks guys.
    jnc and neighbormike like this.
  5. Raycfe
    13,959
    943
    You were missing the harness that plugs into than square connection.
  6. WinHac
    WinHac New Member
    29
    Nov 30, 2016
    Yes and one of the pins was pulled out of the old socket. I dont use battery when canping so 4 wire is fine for me no breaks on camper.
