Changing Tires
Discussion in 'Tires / Brakes / Bearings / Axles' started by Mattda, Apr 15, 2019.
  1. Mattda
    Mattda New Member
    25
    Sep 4, 2018
    I need to replace my tires but not sure how to keep camper off the ground. Manual says to place jack on the frame. So should I use jack stands in all 4 corners of the camper? I'm afraid of warping the floor so I'm not sure of the proper way to do this. Thanks
  2. nineoaks2004
    6,675
    2,607
    Graceville, Florida
    Probably no need for stands on all 4 corners. Unless you are removing all the tires, then it might be a good idea.
  3. Mattda
    Mattda New Member
    25
    Sep 4, 2018
    I forgot to mention I'm replacing all the tires at a local tire store so both need to be removed.
  4. Buckmaster81
    Buckmaster81 Member
    80
    44
    Feb 27, 2019
    Long island NY
    Id do one at a time if it were an option then there is no need to have it lifted like that. You could do say the left side and the spare, then replace the left side with the new tire, jack up the right side and put the spare tire on, go back and get the last one done and use it as the spare. This way you only need one jack stand and a jack.
    If you did feel inclined to do all three at the same time id try to keep the jack stands closer to the axial, maybe a third of the way from the front and back for stability and minimizing frame flex and use the frame rail that the axial is mounted to. Id also lower the stabilizers after it was jacked up just for redundancy..not necessarily taking any weight off but its 4 more points on the ground.
    Just my .02
    Blackripley and Mattda like this.
  5. cam_1100
    cam_1100 Member
    77
    37
    May 10, 2018
    Rochester, MN
    I would put a jack under the axle* and lift it just enough to get the tires off and then put jack stands under the axle(s) near each tire location. That will keep the weight distribution and balance the same as if the tires were still on. There should be no warping at all. The trailer won't know the difference between tires and jack stands since all the weight is being carried by the axle as designed. I did this when I replaced both my tires last year.
    You could also put some blocking or use stabilizers if you have them at the rear of the camper to keep it from tipping up, but that really shouldn't be a problem.
    *If you can easily access the axle with a jack, that is.
    Blackripley likes this.
  6. BikeNFish
    BikeNFish Well-Known Member
    2,481
    1,448
    Apr 24, 2017
    Maplewood, MN
    This is what I do.
  7. Snow
    9,722
    801
    You could buy 2 tire assemblies (tires already mounted on rims) then you would only have to jack up one side of the trailer at a time to change them... Oh and you should buy 3 assemblies, so you can replace the spare tire as well.
  8. J Starsky
    J Starsky Well-Known Member
    619
    389
    Aug 3, 2017
    East Central MN
    This is how I handled my dual axle TT last year:
    Remove one tire, put on the spare. Remove second, slowly let axle assembly down on a block of wood. Jackstands used under axles only, not under the frame or corners.
  9. TheBlurb
    TheBlurb New Member
    18
    Mar 28, 2019
    I just replaced my tires with new ones mounted on new rims. With the sale price, cost was about the same, or lower, as tires alone. Avoided the headache of bringing all existing wheels into the shop.
    As for raising the trailer, I tend to agree with my Jayco manual, which strongly suggests avoiding jacking by the axle: "The camper alignment can be altered causing excessive tire wear."
    xxxapache likes this.
  10. GreyFox
    GreyFox Well-Known Member
    927
    407
    Oct 10, 2018
    S Ontario
    Would help if you told us the make / model / year of camper you have but that said if the owner's manual says to place the jack under the frame then that's what you should do. I'd agree with those who say don't just install new tires on the old rims, it's usually no more costly to install new rims with the tires already mounted on them as you won't be paying a shop to remove the old tires and install new ones on the old rims. Since you're changing just one wheel at a time it also addresses your concern as you'll just be lifting one side of the trailer at a time.
  11. BikeNFish
    2,481
    1,448
    Apr 24, 2017
    Maplewood, MN
    This works only if you want "stock" run-of-the-mill 60-65 mph rated trailer tires. If you want to upgrade to a tire with 80 mph rating, it will be MUCH harder to find them already mounted on a rim. And if you do find them, it probably won't be a very convenient process to get them shipped and installed and you will be most likely be spending more dollars on them than having the local tire shop put the upgrades on your old rims.
    I speak from experience.
    myride and J Starsky like this.
  12. Mattda
    Mattda New Member
    25
    Sep 4, 2018
    Thanks for all the replies guys. I replaced all 3 tires on original rims with a good radial tire from a local tire store. Lifted 1 side off the ground just enough to get tire off and stabilized with jack stand on frame like manual recommended. Took that tire and the spare tire on the first trip. Got home and put the 2 new tires on the camper. Second trip to tire store was for the spare. Wasn't a big deal as the tire store is right around the corner so making 2 trips was fine.
    Buckmaster81 likes this.
  13. Sjm9911
    3,402
    1,595
    I got some from wall mart. Not a top pf the line brand but radials listed 82 mph? Something like that , in the weight capacity i needed. So its possable. Came in a few days free shipping.
    J Starsky and BikeNFish like this.
