cleaning out the crusties
Discussion in 'General Camping Discussion Forum' started by mickeytopher, Aug 25, 2017.
  1. mickeytopher
    mickeytopher Member
    108
    May 20, 2013
    Does anyone have a good way to clean out the crusties from trailer light hookup from my tow vehicle? It's pretty oxidized in one of the female parts
  2. Douggro
    Douggro Active Member
    317
    66
    Jul 26, 2017
    Seattle, WA
    Electrical contact cleaner and compressed air, perhaps a old soft toothbrush to get in the slots. There is also a deoxidizing cleaner for electrical/electronics that you can find through various sources you could try. Just don't insert screwdrivers or other hard tools in the pin openings as this can enlarge them and cause fitment issues.
    J Starsky likes this.
  3. daschnoz
    daschnoz Active Member
    268
    53
    Feb 9, 2015
    Crusties in the female parts... are you sure you have the right forum?
    mrkrag, George Rose, JBinNV and 4 others like this.
  4. J Starsky
    J Starsky Active Member
    415
    229
    Aug 3, 2017
    East Central MN
    Shoot a little carb cleaner in there, wipe out. No carb cleaner, go get a can =) If you gotta scrub, I like a toothbrush or reach in with a tiny dental pick and scrap away - but don't shove stuff in there like our Doug says above. Careful that contact cleaner you buy is safe for plastics or rubber (wire housing). Is this a 7 pin you're working with?
    You don't want crusties on your male or female connectors at all.
    bob barnes likes this.
  5. xxxapache
    2,413
    536
    .22 caliber bore brush, followed by a rinse with carb cleaner or electrical contact cleaner, then topped off with a spray of white grease.
  6. JT2
    JT2 Member
    710
    19
    May 20, 2008
    Go to a good hardware store, then find the housewares section. You want a small "spout brush", specially designed for spouts on coffee pots etc., but also handy for cramming into those socket receptacles. Also, carb cleaner or brake cleaner at the same time. Alternatively, rip a piece of fine sandpaper, roll it to a small size and buff or ream each port.
    Job done, lights work. ( Been there, done that. Frequently!)
    /JT
    mickeytopher likes this.
  7. bob barnes
    bob barnes Well-Known Member
    1,346
    193
    Mar 26, 2017
    everyone should have carb cleaner want to start a stalled motor spray a dab in the carb or take the spark plug out it will run on that stuff but don't do that. I had a float leak in my 4 wheeler I sprayed a dab in the carb week later leak gone!! Cant beat that stuff!1
  8. Mausinn
    Mausinn Member
    48
    26
    Jun 1, 2017
    Washington
  9. mickeytopher
    mickeytopher Member
    108
    May 20, 2013
    Quick update:
    Before we went camping I tried to clean out that one connector that was giving me trouble. Turns out the there was nothing left in there so I was driving with one tail light.
