Coleman outside stove
Discussion in 'Propane - Got Gas' started by scottveazie, Jul 24, 2017.
  1. scottveazie
    scottveazie Member
    51
    Aug 9, 2010
    So my new to me 98 Coleman bayside has the outside stove, but the hose is gone for it. Any idea what kind of hose I need to fix it? It is missing from the crimp at the hose on.
  2. Boatnman
    Boatnman Well-Known Member
    1,444
    324
    Jan 19, 2017
    western Colorado
    Posting a picture or two would help us identify the stove and what you need.
  3. scottveazie
    scottveazie Member
    51
    Aug 9, 2010
    IMG_1015.JPG IMG_1016.JPG No problem. The stoves hose is long gone, I opened it up and it looks like it's missing from the crimp onward. The connection on the trailer is a screw connection
  4. Boatnman
    1,444
    324
    Jan 19, 2017
    western Colorado
    Here's a link to the Parts Book for your PUP:
    https://cdn.shopify.com/s/files/1/0273/4347/files/1998_coleman_grand_tour.pdf?16695232820753828628
    (The cover says "Bayport" but the floor plan says "Bayside".)
    Page 27 shows the parts for the outside stove connection and only calls it a "cylinder adapter". Your picture for the brass fitting looks like it might be a 1" x 20 which is the same treads as a small disposable bottle. Is the propane connection at the side of the PUP the same type of fitting? Whatever hose you get, make sure it is high pressure. (Everything inside the PUP is low pressure.)
  5. Novarich
    Novarich Active Member
    353
    27
    Dec 8, 2014
    Can you post a picture of the fitting where it connects to the stove?
  6. scottveazie
    scottveazie Member
    51
    Aug 9, 2010
    The picture of the threads is the connection at the pup. The stove end has the crimp but the hose that would be in the crimp is gone.
  7. frolin
    frolin Member
    108
    May 13, 2013
    standard high pressure hose, can still be purchased at any walmart, amazon etc. It will be a black hose, withe brass ends, and there is a finger in the middle
  8. scottveazie
    scottveazie Member
    51
    Aug 9, 2010
    Problem is I think it was always attached via crimp to the stove end, as seen on page 25 part number 10
  9. Boatnman
    1,444
    324
    Jan 19, 2017
    western Colorado
  10. Douggro
    Douggro Active Member
    317
    66
    Jul 26, 2017
    Seattle, WA
    Check what Boatnman says: you will probably find that there is a removable nut beyond the crimp where it attaches to the stove. Not many manufacturers are crazy enough to have the hose not be replaceable.. :eek:
    I have the same setup on my pup and I'm pretty sure that the HP hose on the stove is removable.
  11. scottveazie
    scottveazie Member
    51
    Aug 9, 2010
    IMG_1029.JPG Just tried to unscrew it. No dice, it's a double crimp.
  12. Douggro
    317
    66
    Jul 26, 2017
    Seattle, WA
    Do my eyes deceive me or does there appear to be a hex head upline of the crimp between the hose and the stove fitting??
  13. scottveazie
    scottveazie Member
    51
    Aug 9, 2010
    As far as I can tell it's just rounded off, nothing to loosen
  14. Douggro
    317
    66
    Jul 26, 2017
    Seattle, WA
    Well then, I guess we found a manufacturer that was crazy enough to make the hose a non-replaceable item!
    "As the designers studied the plans for their new external camper cooktop, they realized there was a terrible flaw - one that would deprive them of ongoing income ever-after. "Why do we have a replaceable gas line on this thing? Let's use a fixed crimp-on design and we'll be selling whole replacement burner assemblies like crazy and be rich!" Little did they know that consumers wouldn't shell out their hard earned dough for a seldom-used optional appliance part. They were out of business five years later.
    Urban legend has it that many of the designers went on to be software security engineers for Microsoft."
  15. theseus
    theseus Centerville, OH
    2,798
    388
    Feb 6, 2007
    Centerville, OH
    I have this stove. Mine does have a removable hose. I need to tighten it. I am getting a whiff of propane when the stove is off. I'm going to have to hunt until I find the leak. A new stove insert is $200 from colemanpopupparts.com
  16. Boatnman
    1,444
    324
    Jan 19, 2017
    western Colorado
    And it probably cost them more to manufacture it that way.
    Maybe a metal fabrication shop could modify where the crimp is attached to a standard brass fitting for less than $200.
  17. scottveazie
    scottveazie Member
    51
    Aug 9, 2010
    Do you have the exact same stove? I'm tempted to get a regular camp stove and affix it to a larger table
  18. theseus
    2,798
    388
    Feb 6, 2007
    Centerville, OH
    Looks just like that one in the picture. I noted the threaded nut when I was looking for the leak...
  19. Fless
    Fless Active Member
    930
    184
    Aug 14, 2012
    Colorado
    The crimped connection that is shown in your last pic -- is that on the stove end? Where does that hose go?
  20. scottveazie
    scottveazie Member
    51
    Aug 9, 2010
    That's the stove end, main feed for both burners.
