Connecting the car to the camper
Discussion in 'First Time & New Camper Owners' started by Jan Cristo, Jun 25, 2019.
  1. Jan Cristo
    Jan Cristo New Member
    May 24, 2019
    Florida
    How to say this when I don't know the correct names of these things. There is a hitch on the car with a ball on top. I have the connector doodle on the camper. I have a wheel that stays on the camper thingie when we are parked. My question is: how do I get the wheel on and off, what kind of jack do I need or what is the correct way to do it?
    Bigantlers likes this.
  2. BikeNFish
    BikeNFish Well-Known Member
    2,564
    1,537
    Apr 24, 2017
    Maplewood, MN
    Why do you want the wheel off?
  3. Jan Cristo
    May 24, 2019
    Florida
    I don't know. My husband thought it should come off. If this isn't right we'd both love to know the ins and outs of it!
  4. tfischer
    tfischer Well-Known Member
    3,318
    843
    May 21, 2014
    From now on I'm going to call it the "connector doodle" lol
    The wheel on our jack comes off with a pin, but it's pretty obvious so I don't think you would have missed that. We need to take it off for proper ground clearance while towing.
    Sjm9911, Spridle and Jan Cristo like this.
  5. Eric Webber
    Eric Webber Active Member
    200
    124
    Jul 7, 2018
    Montreal, Quebec, Canada
    The trailer thingie (female side that cups around the hitch ball) is called a coupler
    The hitch consists of the ball and the shank which goes into the receiver on the car.
    As for the wheel, some jacks have a removeable foot/wheel that can be swapped in as preferred but most just stay attached and either rotate up (side jack) or raise up (jack in Center hole of coupler)
    Jan Cristo likes this.
  6. Dan Wilson
    Dan Wilson Member
    78
    42
    Jan 30, 2019
    Appleton, WI
    If you are not getting sufficient ground clearance get a hitch with more rise or flip the existing hitch upside down (redoing the ball of course).
  7. Eric Webber
    200
    124
    Jul 7, 2018
    Yup. And try to ride as close to level as possible, barring all other factors. I run a 2-inch rise (shank curves up with ball above)
  8. Jan Cristo
    May 24, 2019
    Florida
    Thank you all so much. And thanks particularly for not shaming me for my lack of vocabulary! The problem is solved (I think).
    Spridle likes this.
  9. gladecreekwy
    548
    545
    Sep 25, 2016
    Pics?
  10. tombiasi
    5,080
    832
    Unless that makes it lower.
  11. tombiasi
    5,080
    832
    How do you stow the wheel jack when in travel?
    Does it pull up and lock with a lever or does it tilt up by pulling a pin and rotating it?
  12. Orchid
    Orchid Sharp Shootin' Grandma
    5,139
    1,804
    May 8, 2011
    Florida by way of WV and MD
    The whole bar when the mini wheel raises on ours, the wheel doesn't come off. There is a pin holding it in place (I think) and you pull that out and push it up.
  13. sleach
    672
    139
    May 17, 2014
    Boulder, Colorado
    Jan, never be afraid to ask a question on this forum. We all learned these things from others. I am personally very thankful to all the folks who helped us out starting in 2012.
  14. MNTCamper
    MNTCamper Active Member
    778
    139
    Jun 14, 2014
    Our tongue jack only goes up and down, does not swivel up. We crank ours up and remove the wheel. Some come with a pin through the wheel and jack pipe, ours has a nub on the wheel portion that slides into the tongue jack and goes up and rotates slightly to lock it into place. Removes in a similar manner. We remove the wheel wheel towing because even up all the way, the wheel sits down some and could easily get hit or sheared off. It only takes a couple of seconds to remove it or put it back on.
  15. kcsa75
    kcsa75 Well-Known Member
    2,540
    1,074
    Sep 9, 2013
    Kansas City
    Shaming? That was one of the most entertaining posts I've read in a long time. Hang in there. You'll figure it out as you go along.
    Remember, the worst day camping is better than the best day at work! ;)
    alabasterjar and Jan Cristo like this.
