Correct LG regulator
Discussion in 'Etrailer.com Trailers and Towing Forum' started by Bothyman, Sep 25, 2017.
  1. Bothyman
    Bothyman New Member
    Sep 22, 2017
    Roanoke, VA
    We have a 1991 Coleman Columbia Pop up with a single 20lb LG tank, the regulator is totally wrecked as the previous owner had dragged it along the road while towing.
    My question is what regulator and hose should we be using as we only have a stove in the camper ?
    McFlyfi likes this.
  2. rabird
    6,347
    167
    TX
    ya got options, but a 2 stage RV regulator.
    if you current have a POL, left hand thread you can go horizontal (vent points down) like
    http://www.rvpartscountry.com/Two-Stage-Regulator-Horizontal-Propane-Regulator.html
    if ya go vertical and a pigtail with an easier ACME connection (right hand - no wrench), you need some place to secure the regulator
    http://www.rvpartscountry.com/Two-Stag-Regulator-Kit-Vertical-Vent-Propane-Regulator.html
    http://www.rvpartscountry.com/Inverted-Propane-Flared-Pigtail-Hose-20-inch.html
  3. Customer
    Customer Well-Known Member
    2,429
    231
    Jun 5, 2014
    Doesn't really matter. You need either a horizontal or vertical two stage LPG regulator set at 11 inches WC. Horizontal or vertical depends on the mounting location, the vent must point toward the ground.
