Dealing with condensation
Discussion in 'Heating / Cooling Systems' started by sallugo, Aug 13, 2014.
  1. sallugo
    sallugo Member
    982
    Aug 6, 2014
    Fort Worth TX
    I recently saw someone use a rain gutter for condensation...anyone know what they used? Or can use? It looked great and would seem it would do the job.
  2. speckhunter80
    4,782
    61
    Jul 26, 2012
    Shell Rock Landing, Hubert NC
    I am going to assume you mean the drainage from the roof mounted air conditioner. If so you can use vinyl J channel or pool noodle/foam pipe insulation
  3. sallugo
    sallugo Member
    982
    Aug 6, 2014
    Fort Worth TX
    "I am going to assume you mean the drainage from the roof mounted air conditioner. If so you can use vinyl J channel or pool noodle/foam pipe insulation"
    Yup, that us what I mean...Thanks!!
  4. swordfish
    swordfish Well-Known Member
    2,204
    32
    Sep 27, 2010
    I just bought some vinyl J channel for this. If you go to the gutter section in Home Depot you will find it.
    I don't intent to make it permanent because I cover my pup in the winter. I will make a track for the J-channel to slide in when in use.
  5. sallugo
    sallugo Member
    982
    Aug 6, 2014
    Fort Worth TX
    When you set up, I would love to see a pic!
  6. sallugo
    sallugo Member
    982
    Aug 6, 2014
    Fort Worth TX
    Oh, by the way...I work at Lowe's so I think I will go there instead [emoji6]
  7. Raycfe
    14,399
    1,072
    Vinyl sliding J moulding. Cut the nailing strip off with a scissors and attach with 3M outdoor mounting tape. Worked great in yesterday's heavy rain.
  8. sallugo
    sallugo Member
    982
    Aug 6, 2014
    Fort Worth TX
    Thanks Raycfe! That's the photo I was looking for...glad it works!!! Do you have it slightly angled for run off?
  9. Raycfe
    14,399
    1,072
    No .... I can adjust the pup to have it run off one corner only.
  10. sallugo
    sallugo Member
    982
    Aug 6, 2014
    Fort Worth TX
    That's what I thought! Great mod!!
  11. swordfish
    2,204
    32
    Sep 27, 2010
    My pup has the aluminum roof, hence there are corner caps. First, I need to flush the edge surface with a <1/4" thick corner moulding (the blue part in the pic) glued to the roof wall, then the PVC cap molding which is acting as flashing. I then can slide in my J-channel leaving a foot out when in use. Everything except the J-channel is permanent; nothing sticking out while towing or under the cover. This is only a concept on paper.
    It will work unless it doesn't.
  12. swordfish
    2,204
    32
    Sep 27, 2010
    It turns out to be exactly as shown in my drawings.
    Here is the gutter track
    With J-channel gutter inside the track
    click image upload
  13. swordfish
    2,204
    32
    Sep 27, 2010
  14. sallugo
    sallugo Member
    982
    Aug 6, 2014
    Fort Worth TX
    That looks awesome swordfish!! Definitely using this idea! Thanks for the follow up and photos!!
  15. sallugo
    sallugo Member
    982
    Aug 6, 2014
    Fort Worth TX
    What kind of glue did you use?
  16. swordfish
    2,204
    32
    Sep 27, 2010
    Silicone caulk. It allows me to adjust and add a bunch of clamps. Hardens after 3 hours.
  17. GMD
    GMD Member
    482
    Mar 18, 2014
    Extremely nice!! Will you do the front of the pup as well?
  18. jrclocks
    jrclocks Member
    585
    Jun 24, 2008
    You don't have to glue anything to your camper. Just slide the J-channel over the lip of the roof.
    The canvas keeps it in place. make it about 6" longer so it doesn't run down you canvas.
    I put about 1 degree of tilt on the camper to direct the condensation to the corner I want to run off. This way you only need one gutter.
  19. swordfish
    2,204
    32
    Sep 27, 2010
    I will start using it by jacking up the front a bit to see if the water follows my command. Hope I can do without the front gutter.
    I have considered at jrclocks' design, but I wasn't able to envision adding the J-channel while I raise the roof. Looks like you need the Sheppard's pole up to jam the J-channel under or by the slits? Do whatever works for you to keep AC drain off the canvas.
  20. jrclocks
    jrclocks Member
    585
    Jun 24, 2008
    On the 2006 Sun Valley, it fit snuggly over the center section of the roof edge and stayed in place while finishing setup. On the 2008 Niagara, I wedged a piece of foam in the center of the J-channel to keep it in place til finished set up. Could just use a piece of velco in the middle like many have used to attach their Gizmos to the underside of the roof.
    I try not to make permanent mods that can't be easily undone.
