Dinette seat back hinge?
Discussion in 'Miscellaneous Repairs & Maintenance' started by Hoyt Burrass, May 23, 2019.
  1. Hoyt Burrass
    Hoyt Burrass New Member
    May 9, 2018
    Montgomery AL
    IMG_4966.JPG Can anybody tell me where I can find this hinge? It is the seat back hinge in the dinette of a 2000 Forest River Rockwood Premier. about 1 3/4 inches long...I might not need the original part as a replacement...convince me that I can go to Lowe's Depot and use any hinge that will fit...
    thanks in advance,
  2. WrkrBee
    WrkrBee Well-Known Member
    1,718
    627
    Yes, go get something better than a plastic hinge.
  3. eoleson1
    eoleson1 Well-Known Member
    1,924
    471
    Jul 5, 2011
    Macomb County Michigan
    I wouldn't even consider replacing that with the original style. Take it up to your local hardware store and find a metal one.
  4. SteveP
    SteveP Well-Known Member
    1,238
    282
    Get the proper length piano hinge and screws at your local hardware store or big box. Much sturdier.
    Natureangel, Sjm9911 and PopUpSteve like this.
  5. erich82
    erich82 Active Member
    143
    69
    Mar 12, 2019
    Is that a plastic hinge?? I doubt that's factory. I can't conceive how anyone would think that's a good idea. Get a good metal hinge with some tapered screw heads so they sit flush with the hinge plate and don't risk ripping your cushions.
  6. Beekeeper1
    Beekeeper1 Member
    32
    Feb 12, 2018
    Whitman Creek, WV
    That is a factory hinge. I just replaced two of the same style or type on my 2005 palimino pony. I use metal hinges from Lowe's.
  7. Orchid
    Orchid Sharp Shootin' Grandma
    4,953
    1,611
    May 8, 2011
    Florida by way of WV and MD
    I agree with all other responses .. any hinge will do. It doesn't even need to be the exact same size. Obviously metal from any store. I've never seen a plastic hinge in my life.
  8. Sjm9911
    3,294
    1,537
    I was going to type what everyone else said. But i won't!
