Does anyone know how to --- adjust the door (2part) on a viking 2008
Discussion in 'General Camping Discussion Forum' started by MARJWEBSTER, Jun 14, 2018.
  1. MARJWEBSTER
    MARJWEBSTER Life is Good
    Mar 21, 2015
    Northern Michigan
    I have an Viking Epic 2008 169 - the door does not line up top to bottom -and there appears to be a gap at the top of the lower portion of the door - The manual says that this is easily adjusted by using the winch handle ?????????????? Anyone have any ideas ????? HELP
  2. Rusty2192
    Rusty2192 Active Member
    672
    193
    Jul 30, 2014
    Kentucky
    The adjustment the manual is referring to is just raising or lowering the roof a bit. If I’m understanding correctly, there’s a gap between the top and bottom parts of the door? If so, just lower the roof a hair till it lines up.
  3. Raycfe
    13,893
    921
    And don't have the stabilizers over tighten, ........ squeezing the body together.
  4. MARJWEBSTER
    Mar 21, 2015
    Northern Michigan
    the gap is in the lower 1/2 of the door - when the camper is lowered all the way there is a vertical gap between the door frame and the edge of the door- wider at the bottom - when set up the door will not stay closed
