Doh! Should I have bought PUGs?
Discussion in 'General Camping Discussion Forum' started by mcbrew, Mar 16, 2014.
  1. mcbrew
    mcbrew Member
    774
    May 22, 2013
    Since we've had a long winter, I've been having fun buying things for the upcoming camping season. I bought a set of PUGs and their bunk end covers, too. What I just remembered is that our 2013 Palomino actually has reflective silver material on the bunks. Does it even make sense to use PUGs on top of that?
    Now, most of the places we camp will be under tree cover, but I do like to camp on the beach at Assateage Island, MD in the summer. That's where I really want some protection from the sun.
    Do a lot of pups have reflective bunk "roof" material? My OLD Starcraft did not. And if so, do you still recommend PUGs?
  2. Unstable_Tripod
    14,279
    24
    May 20, 2008
    Seattle, Washington
    Your PUP may have some sort of silvery/reflective surface but I doubt it it would do what PUGs do. They are actual radiant barriers, like Reflectix. Keep the PUGs and use them all of the time. They help to keep warmer in cold weather and cooler in warm weather. Plus, they keep tree debris and bird poop off your canvas.
  3. mcbrew
    mcbrew Member
    774
    May 22, 2013
    You know that's what I wanted to hear!
  4. RhinoDave
    RhinoDave Active Member
    2,317
    Oct 29, 2008
    Lake Orion, Mi.
    Will it help if I echo what UT said? The main reason I use them is to keep all the cr*p off the bunkends. Camp near some mullberry trees one time and you'll treasure the PUGs
  5. candleems
    candleems Member
    726
    Jul 12, 2006
    South Central PA
    Yup! I use them to keep the crap off the vinyl too.
  6. ghacker
    ghacker Active Member
    3,438
    Nov 8, 2009
    You can also improve the efficiency of the PUGs if you take a pool noodle and cut it into 4 pcs. Place 1 pc. on each side of the Shepards Pole between the PUGs and the tenting. Increasing the dead air space provides more insulation.
  7. skiball
    skiball New Member
    1,295
    Oct 29, 2013
    I understand about the insulation value of the air space. I really don't understand how you are inserting them. Would it work if I cut a pool noodle the length of the bunkend and slid the whole thing in there right above the shepard pole? Or am I in visioning this all wrong?
  8. JETent
    JETent JT
    333
    Jul 7, 2011
    Round Rock, Texas
    GHacker-
    Like Skiball, I am not quite visualizing our noodle deployment. I suppose vertical or horizontal to the shepards pole may not matter, as long as the noodle stays in place (won't wiggle loose in sustained wind or gusts). Any clarification would be much appreciated. Thanks for the great idea.
    Later,
    JT
    Austin, Tx.
  9. woobie
    woobie My PUP is newer than my Tow Vehicle
    163
    Sep 30, 2013
    So...I have four pieces of noodle. Two pieces go on both sides of the Sheppard pole? I don't understand how to place or attach the noodles. Do I slice the noodles?
  10. Fordiesel250
    Fordiesel250 Member
    560
    18
    Mar 28, 2010
    Pictures are needed please
