Dometic Brisk Air II Airbox, bad design.
Discussion in 'Heating / Cooling Systems' started by gottria, Aug 5, 2018.
  1. gottria
    gottria Member
    45
    May 26, 2015
    Castro Valley, CA
    Just replaced my broken Coleman Mach unit with a Dometic Brisk Air II unit. The unit itself works great but the air box on the inside is absolute garbage. Most of the air is distributed to the sides and rear, nothing to the front. The design requires putting screw holes (8) into the ceiling to hold the box into place. Looking through the forums I found a mod to the inside but can't seem to find it it anymore, I did find one that someone built boxes that mount to the sides. http://www.airforums.com/forums/f427/dometic-brisk-ii-install-138335.html
