Dont forget to tighten the AC bolts
Discussion in 'Heating / Cooling Systems' started by bheff, Jun 25, 2019.
  1. bheff
    bheff Active Member
    399
    133
    Feb 24, 2011
    NW Arkansas
    Made a 847 mile trip to find the AC had shifted slightly and the inside valance was barely hanging on. A 5/16th socket on an extension and 8 additional screws later all was good. Didnt have the time or thread lock, but I'll definitely be adding thread lock to the bolts soon. FYI, this is the 2nd unit I've had come loose while traveling.
  2. eoleson1
    eoleson1 Well-Known Member
    2,080
    576
    Jul 5, 2011
    Macomb County Michigan
    Wow! Had no idea such things happened. Guess I'll be wiggling my AC unit now and then! Thanks.
  3. tzmartin
    tzmartin Well-Known Member
    873
    320
    Sep 9, 2015
    Good idea. I've tightened mine a couple of times in 4years
  4. GreyFox
    GreyFox Well-Known Member
    966
    436
    Oct 10, 2018
    S Ontario
    Snugging down the four A/C bolts that secure the ceiling unit to the top unit is fine but if you find these bolts loosening repeatedly it's a sure sign the foam gasket affixed to the underside of the top unit has compressed excessively and should be replaced.
