Door frame gap
Discussion in 'Miscellaneous Repairs & Maintenance' started by jessMN, Jun 14, 2019 at 10:57 AM.
  1. jessMN
    jessMN Member
    30
    May 18, 2019
    Minnesota
    Ok I'm perplexed. The frame next to the door bows out in the middle, so that there is a large gap in the middle and we cannot latch the door - but the door is flush to the frame at the top and bottom. The door itself is level vertically so it's the frame with the problem. What the heck could be wrong here? Frame issue? The pup is also level.
    Pic:
    https://www.dropbox.com/s/dsho0m53pd2x00j/IMG_20190614_083728.jpg?dl=0
  2. Matt Benoit
    Matt Benoit Well-Known Member
    470
    272
    Jul 30, 2017
    Warren, MI
    You have the same problem many of us have had. (including myself). The issue is with the front bunk. It pulls the front wall forward, wich ends up pulling the lower short wall section of the door towards the front, and away from the latch. There may be some water damage in the front wall, or next to the door itself. It's a relatively common problem with pups of that age.
    jessMN likes this.
  3. Matt Benoit
    470
    272
    Jul 30, 2017
    Warren, MI
    There are a few solutions that can help to avoid tearing apart the walls to locate the problem. More support for the front bed, and helping to transfer some of the weight from the bed to the tongue or the ground can help avoiding pulling on the front wall. I recently added an aluminum brace that connects the short wall next to the door with the frame, and it has eliminated my problem... It's not exactly the prettiest solution, but it gets the job done.
    jessMN likes this.
  4. 1380ken
    1380ken Well-Known Member
    1,904
    407
    Nov 7, 2013
    Mass
    Mine was like that and it actually helped to have another stabilizer jack in the rear. I would just mess around with added jacks until it is corrected.
    jessMN likes this.
  5. jessMN
    jessMN Member
    30
    May 18, 2019
    Minnesota
    Thanks everyone me, this gives me some ideas hopefully we can fix it or at least bandaid it
  6. J Starsky
    J Starsky Well-Known Member
    613
    383
    Aug 3, 2017
    East Central MN
    jessMN likes this.
  7. jessMN
    jessMN Member
    30
    May 18, 2019
    Minnesota
    Do you have a pic of that? I'm curious.
  8. Matt Benoit
    470
    272
    Jul 30, 2017
    Warren, MI
    My camper is closed at the moment. So the picture below doesn't show the 90 degree bend in the aluminum that is screwed to the top of the wall. I had a friend place his body weight on top of the wall, while I marked and drilled the hole for the bolt that goes through the frame at the bottom. My door gap used to be similar to yours, and got much worse when someone got in the front bed. This brace has eliminated the problem for me. Hope this helps.
  9. jessMN
    jessMN Member
    30
    May 18, 2019
    Minnesota
    Nice, thanks!!
