1. Jameswilson
    Jameswilson New Member
    Oct 23, 2018
    Can somebody tell me how to drain the water out of holding tank on a Starcraft m-171 I turned the valve underneath the seat and nothing came out. This is my first pop up so I am in the learning process. Thanks
  2. PopUpSteve
    PopUpSteve Administrator
    17,611
    795
    Dec 22, 2002
    Malvern, PA
    If the tank is located under the camper, there may be a drain on the bottom, like an oil pan.
  3. Jameswilson
    Oct 23, 2018
    My tank is inside camper under the dinnet seat I turned the valve that I saw but nothing happened
  4. Customer
    Customer Well-Known Member
    2,429
    231
    Jun 5, 2014
    Gently poke something into the drain from the bottom. It could be plugged with a little sediment.
