Dual LP/CO alarm location
Discussion in 'Campsite Security & Safety' started by MyName, Mar 21, 2018.
  1. MyName
    MyName Active Member
    273
    68
    Jan 12, 2018
    Ca
    HI,
    I need to install my new Dual LP/CO alarm. My popup does not have one so I can't use a existing location. I have kids so they will play a part in it. I was thinking of the short bench where all the power is. Not sure if the aisle or against the wall would be better. Any suggestions?
    MTI Industries 35-742-WT Safe T Alert 35 Series Dual LP/CO Alarm - Flush Mount, White
    My Layout.
  2. McFlyfi
    McFlyfi Active Member
    349
    141
    Aug 1, 2014
    Thousand Oaks CA
    The propane leak detector is usually mounted close to a propane appliance. My fridge, stove and furnace are all right next to each other, the detector is mounted on the wall at the back bunk, right next to/below the stove and furnace. I'd put it right next to to your stove I the wall shared with the storage trunk.
