February 2011 Recipe of the Month
Discussion in 'Recipe of the Month' started by PopUpSteve, Feb 1, 2011.
  1. PopUpSteve
    PopUpSteve Administrator
    18,555
    1,403
    Dec 22, 2002
    Malvern, PA
    Submitted by: 01YZF6
    Title: Stuffed Chicken Breasts
    Serving Size: 6 people
    Ingredients:
    • 6 boneless chix breasts
    • 1 lb cream cheese
    • 1 jar salsa (optional)**
    • 1 lb bacon
    • worcestershire or teryaki sauce
    • pepper
    Directions:
    Here are the directions for cooking this one of three different ways:
    Cook at Home:
    [list type=decimal]
    [*]Preheat oven to 400 degrees
    [*]Thaw out and flatten chicken breasts from the bottom side with a meat mallet ( not the pointy tenderizer end)
    [*]Slice cream cheeses into 1/2" slices and place on one side of each chix breast. (4 slices per should work)
    [*]**Spoon thick salsa over cream cheese and fold/roll chicken over
    [*]Wrap 2-3 slices of bacon around each breast, pin with toothpicks from the top.
    [*]Place in a 12x18 glass pan with toothpick sides up.
    [*]Bake for 30 minutes
    [*]Remove from oven
    [*]Pour worcestershire sauce or teryaki marinade over chicken
    [*]Add pepper to your taste
    [*]Bake for 15 more minutes at 400 degrees
    [*]Turn oven on LOW broil for 5 minutes. This browns the top of the bacon and sauce a bit more.
    [*]Remove and serve with your favorite side.
    [/list]
    Grill Cooking:
    [list type=decimal]
    [*]Preheat grill to 350-400 degrees
    [*]Place chicken on tinfoil covered grates
    [*]Close lid, check on every 15 minutes, moving around chicken for even cooking
    [*]Do not turn chicken upside down
    [/list]
    Dutch Oven Cooking:
    [list type=decimal]
    [*]Depending on the size of your DO, depends on how many you can cook at a time
    [*]In a well seasoned and freshly greased DO, place chicken inside, spaced 1" apart
    [*]Add Worcestershire sauce over the top of chicken. pepper to taste
    [/list]
    Comments and Thoughts Welcome!
    Click Here to learn how the contribute a Recipe or Read Previous Ones!
  2. 01YZF6
    01YZF6 Dothan, AL
    2,336
    Apr 5, 2008
    Mt. Washington, NH
    thanks Steve !
  3. Richard
    Richard Take kids camping. It's great for you and them.
    278
    Dec 11, 2007
    Blue Ridge Mountains, Tennessee
    Sounds Yummy, can't wait to try it. I'm always up for a new twist on Chicken Breasts.
  4. 01YZF6
    01YZF6 Dothan, AL
    2,336
    Apr 5, 2008
    Mt. Washington, NH
    here is a heating guide from Lodge, based on DO sizes
    OVEN SIZE ----------- TEMPERATURE DESIRED
    -------------NUMBER OF COALS
    -------------------TOP/BOTTOM
    [table] [tr][td]Oven Size
    [/td] [td] 325
    [/td] [td] 350
    [/td] [td] 375
    [/td] [td] 400
    [/td] [td] 425
    [/td] [td] 450
    [/td] [/tr] [tr] [td] 8”
    [/td] [td] 15
    [/td] [td] 16
    [/td] [td] 17
    [/td] [td] 18
    [/td] [td] 19
    [/td] [td] 20
    [/td] [td] 10/5
    [/td] [td] 11/5
    [/td] [td] 11/6
    [/td] [td] 12/6
    [/td] [td] 13/6
    [/td] [td] 14/6
    [/td] [/tr] [tr] [td] 10”
    [/td] [td] 19
    [/td] [td] 21
    [/td] [td] 23
    [/td] [td] 25
    [/td] [td] 27
    [/td] [td] 29
    [/td] [td] 13/6
    [/td] [td] 14/7
    [/td] [td] 16/7
    [/td] [td] 17/8
    [/td] [td] 18/9
    [/td] [td] 19/10
    [/td] [/tr] [tr] [td] 12”
    [/td] [td] 23
    [/td] [td] 25
    [/td] [td] 27
    [/td] [td] 29
    [/td] [td] 31
    [/td] [td] 33
    [/td] [td] 16/7
    [/td] [td] 17/8
    [/td] [td] 18/9
    [/td] [td] 19/10
    [/td] [td] 21/10
    [/td] [td] 22/11
    [/td] [/tr] [tr] [td] 14”
    [/td] [td] 30
    [/td] [td] 32
    [/td] [td] 34
    [/td] [td] 36
    [/td] [td] 38
    [/td] [td] 40
    [/td] [td] 20/10
    [/td] [td] 21/11
    [/td] [td] 22/12
    [/td] [td] 24/12
    [/td] [td] 25/13
    [/td] [td] 26/14[/td][/tr] [/table]
    remember to have enough coals on standby to maintain proper and even heat (coals on LID / coals under DO)
  5. 01YZF6
    01YZF6 Dothan, AL
    2,336
    Apr 5, 2008
    Mt. Washington, NH
    I will be making a new variation of this tonight...
    the filling will be
    using 1 lb of fresh chopped Spincah, rinsed and paper towel wrapped to dry out a bit.
    1 lb Ricotta cheese
    3 oz minced garlic
    on the outside, Instead of bacon, when the chicken is done, I will moisten the outside by rubbing it with butter ( stick) then rolling it in self rising flour and panko bread crumbs, and frying it for 15-30 seconds to give it a nice crisp shell.
  6. 01YZF6
    01YZF6 Dothan, AL
    2,336
    Apr 5, 2008
    Mt. Washington, NH
    the side dish is a Pasta salad mixed light ranch dressing, cucumbers, zucchini, and finely shredded colby-jack cheese.
    I had some thinner pieces of chicken breasts, so I cut them into strips, dipped them into milk, floured both sides with self rising flour, mixed with garlic powder and pepper... PAN FRIED on med heat with 2 tbsp canola oil
    cooked 4 minutes total. turning them over every minute.
  7. starcrafty
    starcrafty Guest
    How does the air temp affect these guidelines? My DS's Scouts camped this weekend in 210 F weather. In March, the Scoutmaster will be on Camp Staff for a campout, and asked me fill in as Asst SM. Of course, the Scouts make their own menu and cook, but I will have some input. Don't know what the temp will be, but still wondered.
    Thanks
  8. 01YZF6
    01YZF6 Dothan, AL
    2,336
    Apr 5, 2008
    Mt. Washington, NH
    air temp can affect cooking in various ways. as can wind, humidity, sunlight or shaded/overcast areas.
    I would GUESS, that if the temps are between 30-60 degrees outside, and breezy ( typical southern March, right?)
    that you would just need to rotate the old coals out for fresh ones a bit more frequently to maintain a good, even, temperature.
    I would not ADD more coals on the DO itself to compensate though.
    just some general user tips.
    hope this helps you some.
    http://www.superior-cast-iron-cookware.com/dutch_oven.html
    http://www.troop525.org/contents/DOCooking_content.htm
  9. starcrafty
    starcrafty Guest
    Thanks. I'll let you know how it turns out.
