Figuring out power: Furnace, Fridge, etc
Discussion in 'First Time & New Camper Owners' started by SimonSenz, Jun 19, 2019.
Tags:
  1. SimonSenz
    SimonSenz Member
    33
    Jun 18, 2019
    Ok. Next questions. I was just taking a photo of the fuses so I could go to the hardware store and buy an extra set (the right ones). I noticed the fan in the fusebox was blowing. I checked the buttons - both were on red and green and the metal was hot. The propane was not turned on and the fridge was not cold. Did I screw something up?
  2. SimonSenz
    SimonSenz Member
    33
    Jun 18, 2019
    we are plugged in at the house still.
  3. Sjm9911
    3,660
    1,799
    The fan runs when the electrical box gets hot.
  4. BillyMc
    BillyMc Well-Known Member
    698
    288
    Mar 25, 2018
    I run the fridge on 12v while traveling, 110v when connected to shore power, and propane while off grid. If you use 12v make sure the TV charges the battery while connected. Only use one power source at a time on your fridge.
  5. Anthony Hitchings
    294
    97
    Mar 2, 2019
    Actually, if the flame goes out the thermocouple cools off and the gas solenoid closes - there is no safety issue. Same as the old fashioned (non-electronic water heaters).
    Snow likes this.
  6. HappyTraveler
    HappyTraveler Active Member
    201
    136
    Apr 30, 2019
    New York
    Totally agree, block ice is the better choice for keeping your ice chest cool. Problem is it's REALLY hard to find. In all our years of camping, we've only found it once and that was two years ago in Arizona...and only at one specific convenience store.
    The ice cubes melt much faster, so don't last as long. From what I've heard, the little counter top ice cube makers you can buy make "soft ice", which means it's great for drinks, but melts too fast to be much use in an ice chest.
    When we can find it, we buy some dry ice to freeze the water (or melted water from cube ice) in the ice chest to make block ice. That ice block will last 3 or 4 days then in 60 degree heat if the ice chest is kept covered and not in the sun. Otherwise, we're having to get the bags of ice cubes every day or every other day if we feel like living dangerously. ;)
