Flagstaff t21tb electricity issues
Discussion in 'A-Frame PopUps' started by 3amigos, Jul 13, 2018.
  1. 3amigos
    3amigos New Member
    24
    Mar 18, 2018
    Hi,
    We are new to this. we have a flagstaff t21tbhw. It is currently plugged into our house with a 30 amp converter. the first couple of days we slept in it to try it out and everything worked fine. a couple of weeks later, the fan won't work and the lights are very dim. the air conditioner works great. It's as though the battery is going dead (or is dead) to the lights and fan, but since we're plugged in, that shouldn't matter, should it? Any tips on what is going on? thank you!
  2. joet
    3,667
    554
    If your converter has the ability to charge a battery, the battery should be fully charged. Do you have a volt meter? I would look at fuses first.
  3. 3amigos
    3amigos New Member
    24
    Mar 18, 2018
    Thank you..I’ll look at the fuses.
  4. 3amigos
    3amigos New Member
    24
    Mar 18, 2018
    Yep, replaced a fuse and the lights are working. Fantastic fan started to work, but then stopped. I think I may need to try pressing down on the plunger under the lid...at least that’s something I’ve read. I’m guessing maybe there is a loose connection somewhere, if the plunger isn’t stuck. At least we’re making progress. Thanks for the help!
  5. 3amigos
    3amigos New Member
    24
    Mar 18, 2018
    Oh...and the battery was fully charged...
