Fleetwood E3 - Sagging AC Roof Assembly
Discussion in 'Heating / Cooling Systems' started by JETent, Mar 15, 2018.
  1. JETent
    JETent JT
    333
    Jul 7, 2011
    Round Rock, Texas
    Hello Portal. I opened up the E3 this afternoon and noticed the front right corner of the AC Roof assembly was sagging loose from the ceiling. Not a panic situation. Looks like one of the spring loaded mounting screws may have pulled loose from the internal metal control box(?).
    Anyone ever dealt with this one before? I am going to loosen the spring loaded screws and see what happens...meanwhile I will see what other folks may know about this topic. Either way I will follow back up with what I discover. As always, thank you in advance for any help or guidance.
    JETent
