Furnace blower won’t turn on
Discussion in 'Heating / Cooling Systems' started by Mwbaker0729, Sep 16, 2018.
  1. Mwbaker0729
    Mwbaker0729 New Member
    Sep 16, 2018
    Coeurdalene ID
    I have a 1989 Coleman Chesapeake and I think I lit the furnace in the wrong order. It ran for a few minutes and then **** off. The pilot light was still lit but the blower never turned back on, then I read the manual and saw that the blower needs to be running first before you light it. After following the instructions in the manual, the blower does not turn on at all. I need help.
  2. nineoaks2004
    6,632
    2,583
    Graceville, Florida
    The outside temp might be to high for it to run. You might have to jumper the thermostat to get it to run.
    PopUpSteve likes this.
  3. Mwbaker0729
    Sep 16, 2018
    Coeurdalene ID
    The outside temp was below 60. When I followed the instructions it said to turn it on and set temp all the way up and wait for blower to turn on before lightning the pilot. It never turned on.
  4. nineoaks2004
    6,632
    2,583
    Graceville, Florida
    Could be air in the lines too and might take awhile to clear the air, another thing to check is the sail switch, ( I have worked on a few of them that had a dirt dobber nest on the blade and will not open up with the extra weight.
  5. Mwbaker0729
    Sep 16, 2018
    Coeurdalene ID
    The system was already running for the stove and fridge, so I don’t think there was air in the lines. My brother in law and I took the furnace apart before initially lighting it and did a good cleaning. Where is the sail switch? Is there any type of safety reset button on the furnace itself anywhere?
  6. PopUpSteve
    PopUpSteve Administrator
    18,370
    1,268
    Dec 22, 2002
    Malvern, PA
    Is there a separate start button for your furnace?
    All the ones I've dealt with need:
    • Power in the form of Battery (DC) or Shore Power (AC).
    • Propane to be on
    • The Thermostat to be set to the desired temperature.
    • And the Thermostat turned ON.
    As stated above, if the current temperature around the Thermostat is higher than the set temperature, the furnace will not light.
  7. PopUpSteve
    18,370
    1,268
    Dec 22, 2002
    Malvern, PA
    There could also be a blockage in the line for the furnace. Spiders love getting into the jet opening.
  8. Mwbaker0729
    Sep 16, 2018
    Coeurdalene ID
    My unit has a converter for 12v or 110. I had it hooked up to 110 this last weekend. I am not sure if the exact temp at the time I was trying to light it, but I know it was chilly. In the 50’s
  9. tombiasi
    4,952
    716
    Some units shut down if there is a problem and won't restart for a specific amount of time.
  10. PopUpSteve
    18,370
    1,268
    Dec 22, 2002
    Malvern, PA
    Can you hear the heater "clicking" but the blower doesn't come on?
  11. Mwbaker0729
    Sep 16, 2018
    Coeurdalene ID
    I waited until the the next night, last night to start the furnace again. The blower never turned on.
  12. Mwbaker0729
    Sep 16, 2018
    Coeurdalene ID
    I did not check for that. I don’t understand why the blower wouldn’t even turn on though
  13. Mwbaker0729
    Sep 16, 2018
    Coeurdalene ID
    It is a Hydro flame Everest Star 79/80 series furnace
  14. tombiasi
    4,952
    716
    You need to check DC power to the unit. Fuse?
  15. Mwbaker0729
    Sep 16, 2018
    Coeurdalene ID
    The manual for the furnace says that there is a circuit breaker button on the front of the furnace. I am going to check that.
  16. jnc
    3,909
    1,157
    Oct 1, 2014
    South Central New Hampshire
    I would check the little switch on the thermostat. They are a pain to move and you may not have it turned on all the way.
  17. joet
    4,122
    710
    Put a jumper on the T-stat. This eliminates that question
  18. tfischer
    tfischer Well-Known Member
    3,228
    758
    May 21, 2014
    Something is off here that nobody has mentioned yet. You mention lighting pilot lights, etc... but this heater (and every RV heater I know of) doesn't use a pilot light... it uses an electric spark to light the gas every time the t-stat calls for heat.
  19. Sjm9911
    3,308
    1,542
    Good point!
    Some have an on off switch on the bottem of the thermostat. People miss it because it's so low to the ground. I think mine might have a switch on the inside of the heater for the blower.
  20. tenttrailer
    3,078
    252
    Jul 18, 2013
    Thornville, OH
    Many furnaces, if the furnace tries to light but does not light, it goes into a lockout mode and it will do nothen after that. You might need to turn the on/off thermostat switch to off for about 10 seconds before trying it again.
    But it should not mater if the pilot is on, if you have a manual pilot light? Have not seen a manual pilot light on the camper since a 1977 camper. Are you sure its manual??
    The furnace will not light if the battery voltage is to low. But many times the fan will run, but the furnace will not light. It has to do with the control board needs a minimum voltage.
