Furnace - can’t turn on?
Discussion in 'Heating / Cooling Systems' started by TheBlurb, Mar 28, 2019.
  1. TheBlurb
    TheBlurb New Member
    Mar 28, 2019
    How can I get my furnace to turn on? I recently bought a used tent trailer, whose previous sole owner said the furnace worked, but they didn’t use it.
    I found and connected red and white wires to the thermostat (they weren’t connected). Propane and electricity are connected. A switch on the furnace is on. But when I move the thermostat lever all the way on, nothing happens.
    Trailer is a 2003 Jayco QWest. Furnace is factory installed. Thermostat is a Suburban 1c20-130 — original I think (strangely mounted on the side of the movable countertop).
    Maybe the thermostat needs replacing? Any help is much appreciated!
  2. Halford
    Halford Well-Known Member
    3,555
    512
    Sep 28, 2011
    Santa Clarita, California
    need to light the pilot light?
  3. Matt Benoit
    Matt Benoit Active Member
    411
    228
    Jul 30, 2017
    Warren, MI
    Bypass the thermostat... Disconnect the wires you reconnected and twist them together. This will rule out a thermostat issue.
    Buckmaster81 likes this.
  4. jmkay1
    4,186
    1,099
    If the furnace has not been used in a long while , I would also look in to see if any bugs, made a nest in it.
  5. Pozi
    Pozi Member
    88
    25
    Feb 17, 2016
    It could be any number of things. But as mentioned already bugs and t-stat is where I would start.
    Does the fan kick on at all? Are you getting 12v to the furnace? If the t-stat wires were disconnected maybe the furnace was disconnected too???
  6. Sjm9911
    3,023
    1,297
    What they said! Also check for an on off ssitch on the bottem of the t stat.
  7. TheBlurb
    TheBlurb New Member
    Mar 28, 2019
    Thanks everyone! Manuals for trailer/furnace say there is no need to light a pilot. Trailer is very clean; no evidence of bug problem. No fan kicks on. No switch on thermostat. I will test Matt's idea and double check 12v is getting to furnace.
  8. jmkay1
    4,186
    1,099
    The bugs could have gotten in through the vent from outside and crawled in the piping. unless you have screen blockers on the outside vent. Check there then go on the inside and take the furnace vent cover off and look to see if there are any signs of bugs in there. Also while the vent cover is off does there appear to be a switch you need to turn on or anything appear disconnected?
  9. crackerJack
    crackerJack Well-Known Member
    1,086
    264
    Jan 6, 2014
    Scottsville, KY
    Install new digital heat only thermostat.
    That would upgrade and eliminate that possibility.
  10. Buckmaster81
    Buckmaster81 Member
    72
    41
    Feb 27, 2019
    Long island NY
    Did you check for a blown fuse or tripped breaker?
  11. daveo1289
    daveo1289 Active Member
    948
    43
    Apr 24, 2012
    Rochester NY
    You state that the fan does not kick in. Start with the electrical system. Make sure the 12DCV is at the furnace and t-stat. If at the furnace and not the t-stat, the t-stat wiring will have to be checked for continuity. If not at the furnace, then you'll have to go back to the power panel. You may have to turn the switch on the furnace to off and the on to reset it. That will tell you if the switch is OK by the sound and feel of it. You can also test it with your meter. Big thing is not to overload yourself trouble shooting the issue. Start by getting the fan to run. Then proceed from there.
