Furnace installed!
Discussion in 'Heating / Cooling Systems' started by CampIsLife, Apr 21, 2019.
  1. CampIsLife
    CampIsLife New Member
    Jul 23, 2018
    Calgary
    Finally furnace is hooked up!
    Our 91 Coleman Ronake came without any appliances no battery or propane.
    I parted out a rotton starcraft starlite 21 & scored all the appliances & they all worked correctly.
    I finished plumbing in furnace it works great heats up nice & its quiet:)
    Last step is to cut hole in the roof & Install vent. I already ordered a vent unfourtunlety it ended up being damaged, big crack down 1 corner. Replacement should be here Wednesday!
    Thanks to all who helped with my questions, best popup Forum out there:)
    crackerJack and Sjm9911 like this.
  2. neighbormike
    1,767
    984
    Oct 6, 2012
    WI
    Good work! Looks like a nice, clean install! And you will appreciate a good furnace!
    CampIsLife likes this.
  3. Sjm9911
    3,018
    1,290
    Cool , look factory installed!
  4. Wrenchgear
    3,129
    443
    Aug 5, 2010
    5 Star Eagle Camper
    Another great job. good work! Now the wife will be warm as well as not having her arm bitten by mozzies all night long.
