Furnace woes....
Discussion in 'Heating / Cooling Systems' started by eyefly12, Mar 29, 2007.
  1. eyefly12
    eyefly12 New Member
    93
    Jan 3, 2007
    A question for you cold weather campers...
    We have a 2007 Rockwood with the propane furnace with electric ignition. We have only had it out twice, but it has been cool enough at night that we want a little heat, mostly for the DS, 2 yrs. old.
    I am thinking that something is wrong with the furnace or thermostat! I set the temp on the thermostat to get the heat going, and it does! It gets hot inside, around 80 deg. Then, it runs fan only for a while, and shuts off. Obviously it starts to cool off, but gets all the way down to 60 deg. before turning on again, and warming up to 85 again. This doesn't seem right to me!
    Is this how they all work with the cheap thermostats that are used?
    Do I need to turn this in for warranty replacement?
    If this is pretty normal, does the change to the digital style help this problem?
    It gets us plenty warm! We start to sweat, then it cools off so much that you get cold, and cycle through the whole process over again!
    Any info and/or experience will be greatly appreciated!
    Thanks!
    eyefly12
    BCStrait '74
    DW '71
    DS '04
    George DDog '02
    TV: 2000 Jeep Grand Cherokee
    PUP: '07 Rockwood 1910
    Nights Camped in 2007: 3
    Nights Reserved: 8
  2. West Coast Canuck
    1,631
    48
    Mar 3, 2005
    Sounds like your thermostat may be giving you problems..mine does cycle for a little while and then shuts off
    2004 Dodge Ram 1500 QC Hemi Laramie 4x4 (TV)
    1994 Starcraft
    Starflyer 1021 PU
    John 46
    Kim 46
    Wayne 24
    Christie 20
    Cindy 18
    Coco - Born Jan 7, 2006...new pup...lol
    For photos-
    http://s68.photobucket.com/albums/i19/westcoastcanuck/
  3. Beerlifter
    Beerlifter Oklahoma, It's not just for Indians anymore!
    878
    Jun 22, 2006
    Oklahoma City , Oklahoma
    Do a search on Thermostats...seems like I have read that there is an adjustment in the stat for the cycling period. Most people have just replaced the cheap stats with ones from Home Depot or the likes
    Steve
    Laura
    DD Tara
    DD Autumn
    '02 Chevy Silverado
    '96 Jeep Grand Cherokee
    '95 Dutchmen 1002
    '83 Coleman Columbia (sold)
    http://community.webshots.com/user/beerlifter
    http://lastchancecampground.com/default.aspx
  4. mercman
    mercman Go Ahead, Be That Happy Camper!
    2,921
    36
    Jan 7, 2007
    Western MA
    Eyefly,
    This is from the thermostat manual that came with my 2007 Rockwood...
    sympton- Furnace cycles too fast or too slow-
    narrow or wide tempature swings
    Corrective action- Adjust anticapator...
    quote-The anticipator should be set to match the current rating(amps) stamped on your main heating control Adjust the anticipator by rotating the contact arm. The anticipator setting is indicated by the numbers on the base that the pointer points to. (It looks like a timer dial in the diagram). Move the pointer counterclockwise to lenghten heating cycle, move clockwise to shorten cycle. Adjustments should not be greater than 1/2 marking at a time. -end of quote
    hope this helps
    Chris
    01 f-150
    07 Rockwood 1980,
    The official vehicle of the Camping Collies.
    64 Mercury Comet
    Happy To Be The Wondering Wanderer...
    ...as long as I end up with sand in my toes
  5. eyefly12
    eyefly12 New Member
    93
    Jan 3, 2007
    Thanks Chris!
    I need to go get my manuals out! I will have to play with the settings, etc. Not sure how this will work now, as the temps are in the 80's here now, and I would have to run A/C and furnace to keep the temp down to test it....
    Summer is coming fast!
    Thanks for the info!
    eyefly12
    BCStrait '74
    DW '71
    DS '04
    George DDog '02
    Nights Reserved: 8
