Furnace won’t turn completely off
Discussion in 'Heating / Cooling Systems' started by MaeKay, Mar 30, 2018.
  1. MaeKay
    MaeKay Active Member
    591
    185
    Oct 18, 2017
    Utah
    On our 2007 Bayside I finally realized that the thermostat doesn’t actually turn off when I switch it to off for the day. It cycles properly and keeps the trailer at the right temp during the night. But then after I switch the flip to “off”...it still comes on. I have to lower the temp as low as it goes to get it to turn off.
    Does this mean we need a new thermostat or is there a deeper problem with the furnace? Luckily the temps are above the lowest setting during the day time so I’m not wasting propane, although if they were I’m not sure how to stop it short of turning off the propane at the tanks and unplugging the battery.
  2. NMroamer
    NMroamer Active Member
    433
    194
    Apr 21, 2016
    Albuquerque NM
    Pop the cover off the thermostat and visual check that it is working.
    MaeKay likes this.
  3. jnc
    3,909
    1,157
    Oct 1, 2014
    South Central New Hampshire
    You could disconnect the Thermostat. The switches are a PITA. My guess is that its not turned off all the way. @NMroamer said take the cover off and you can see what the switch is doing.
    Fbird and MaeKay like this.
  4. nineoaks2004
    6,668
    2,606
    Graceville, Florida
    X3 If it is the thermostat a new digital one can be had from Wally World for less than $20.00
    they are easy to install . Good Luck and happy Camping
    MaeKay likes this.
  5. MaeKay
    591
    185
    Oct 18, 2017
    Utah
    Thanks! I briefly tried removing the cover but it didn’t want to come off. It looks like the old brown stock one.
    I’ll keep trying.
  6. jnc
    3,909
    1,157
    Oct 1, 2014
    Just stick a screw driver under the edge.
    MaeKay likes this.
  7. thethird152
    thethird152 Active Member
    616
    100
    Feb 1, 2015
    Mt Pleasant, MI
    The switches on those old brown tstats are notorious for requiring a great deal of force to throw. My first check would be to make sure you're turning the switch all the way to the 'off' position.
  8. MaeKay
    591
    185
    Oct 18, 2017
    Utah
    I did. I can feel it click. That was my first thought, too. Did I just not push it hard enough? At least from the outside of the box it’s clicking and I can’t push it any more.
  9. Fbird
    Fbird Active Member
    262
    113
    Sep 10, 2017
    Ferndale MI
    they are good for feeling like they'll break, if you pull the cover off and watch it while you switch it it'll flex and look like it's going to break. I got tired of fighting with mine and replaced it with a digital on.
    MaeKay likes this.
  10. MaeKay
    591
    185
    Oct 18, 2017
    Utah
    I’d prefer a digital one as well. Maybe before our next trip! The lows where we’re going is supposed to be 68.
  11. Grousetales
    Grousetales New Member
    Mar 19, 2017
    I always thought I was turning mine off, until I took the cover off last fall and observed the switch in action. It turns the little "click" I was feeling was not the off position. It took quite a bit of force to push it into the off position. Now I know where the off position is, and if there is any questions, I pop the cover off to confirm.
    MaeKay likes this.
  12. Fbird
    Fbird Active Member
    262
    113
    Sep 10, 2017
    Ferndale MI
    funny where i'm going I'm hoping it makes it up to 38, the lows will be in the teens.
    jnc and MaeKay like this.
  13. MaeKay
    591
    185
    Oct 18, 2017
    Utah
    But that’s why we have trailers, right?! To extend the camping season! We went camping for my birthday in November with nighttime lows below freezing and were toasty comfy. Which was a nice thing since it was our first trailer trip!
  14. MaeKay
    591
    185
    Oct 18, 2017
    Utah
    Wow! You guys weren’t kidding! I took the cover off and what I *thought* was the click was NOT. There is a distinct hard push to get it to turn off. I feel much better now. The thermostat mod can wait a little bit now. I am just way too busy.
    Fbird, thethird152 and Grousetales like this.
  15. jnc
    3,909
    1,157
    Oct 1, 2014
    I used a tiny hammer and worked the switch back & forth until it got a little easier to move. I will probably need to do it again this season.
    MaeKay likes this.
